Another G37x with swift springs installed
Old 08-16-2015, 09:15 PM
si_driver
si_driver's Avatar
Hey guys,
just installed the swifts on my AWD today and took a nice test drive.
These are def. much stiffer than stock and you can feel a lot of bumps etc. Your wife or girlfriend may not approve the ride quality if she isn't into cars but for anyone else it is acceptable.
The ride does will a little bouncy in the rear but maybe after a couple of days the springs will feel better.
Even though the car rides much stiffer I do like it and it appears to handle better than stock. I def. like to little drop look better than stock.
Here are the after pics: I did brighten the photos in photoshop so the wheels and tires show a little better - for anyone who wants to see the gap better.
The following 3 users liked this post by si_driver:
Awgd8 (08-16-2015), m3clubracer (08-18-2015), mdmill1 (08-17-2015)
Old 08-16-2015, 10:01 PM
Awgd8
Awgd8's Avatar
Nice! Thanks for posting some pics! I will do mine next year after this coming winter.
Any camber kits installed?
Old 08-16-2015, 10:38 PM
Broski28
Broski28's Avatar
Looks great!
Thumbs up for quality pics too!
I will be putting mine on this weekend
Old 08-16-2015, 11:37 PM
Received 4,940 Likes on 4,174 Posts
Nice work, glad the install went well.
Old 08-17-2015, 07:50 AM
si_driver
si_driver's Avatar
for anyone interested, the install was very easy.
Just one bolt in the rear and a couple in the front.
Not sure if 2wd is the same but AWD was very easy up front and can def. be done by one person fairly quickly.
To make things much easier make sure to also unbolt and separate the upper control arm.
Drove 30 miles to work this morning, and the like the feel of the car a lot more than stock. Yes, it is stiffer and you really have to be careful riding over bigger bumps and potholes. I am also thinking that the stock strut and shock will wear quicker. But the cost to replace them probably isn't too great.
Old 08-17-2015, 07:54 AM
si_driver
si_driver's Avatar
No, no camber kits .....
Old 08-17-2015, 08:02 AM
Received 4,573 Likes on 3,424 Posts
The AWD Swifts sure seem to do the job perfectly. RWD Swifts, not so much.
Looks spot-on to me, OP. Some people like a zero gap at the top, but I much prefer the look of an even (ish) gap around the curve of the fender, which is what you seem to have accomplished here.
Old 08-17-2015, 09:51 AM
VIVID
Pyroclastic Flow
VIVID's Avatar
Looks great. More 'planted'. I too have an X sedan and your end-result looks very similar to mine with Eibach springs.
And as you describe it, your ride characteristics are similar to mine as well. The Eibachs mellowed a bit after a couple of hundred miles. I did add sways and F&R camber kits at the same time so that's a variable or two that may create dissimilar experiences going forward.
Sean
Old 08-17-2015, 11:26 AM
botlfed98
botlfed98's Avatar
I assume you reused your stock shocks? just curious how many miles you have on them?
Old 08-17-2015, 11:28 AM
si_driver
si_driver's Avatar
I am at 48k right now.
Old 08-17-2015, 05:44 PM
VIVID
Pyroclastic Flow
VIVID's Avatar
I'm at 10,100 miles at this point. The springs were installed at 9700.
Sean
Old 10-31-2015, 05:56 PM
Mattlorentzoe
Mattlorentzoe's Avatar
Interested in an update from y'all who have the springs on your X. I'm not interested in dropping the car a lot but the stock springs seem to let the rear shake a little? Wondering if coil overs is the way to go or if springs could get it done? Mainly going for stiffer feeling in the back is the symptom I'm trying to solve
Old 05-05-2017, 02:52 PM
Akmattic
Akmattic's Avatar
How's the ride to date? Any other issues? What is your tire setup? Thanks for the write up. Considering going the Swift spring route myself.
Old 06-05-2017, 03:37 AM
amh085
amh085's Avatar
I just purchased swift springs on Amazon. They should arrive by Tuesday. Also picked up some tsw vale 20's which I plan on throwing on too Given all of this, I'm at about 74k on the odometer. Am I fine to ride with my stock shocks? I saw a post on here of someone with 97k and they are sitting fine, it seems. Or would I be better off going with some Aftermarket monroe shocks
to go along with the swifts?
Since we are Awd sedan, the ever popular konis won't work as far as I can tell. The only other alternative I've read on another thread is to purchase g37s rear shocks. But that just covers the rears and not the fronts.
Thoughts or recommendations? If there's anyone who has a similar setup like this, please provide your feedback.
Old 06-05-2017, 09:06 PM
Coltrane1
Coltrane1's Avatar
with only 74k I'd say install and enjoy them, i.e., if it ain't broke don't fix it would be my choice. I only went the C/O route because my X model had more than 100k. It will be interesting to see what suggestions you receive. All the best!
amh085 (06-06-2017)
Quick Reply: Another G37x with swift springs installed
