PDA
View Full Version : Brakes & Suspension
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41
  1. Akebono ProAct or Performance Ultra Premium
  2. G37 under the knife for some mods
  3. 2010 G37x Swift springs
  4. How long can rotors last with worn out pads?
  5. Pic of 1 inch dropped Sedans (preferably AWD)
  6. Fortune Auto Muller Air Cup lift system
  7. VDC/abs/slip light
  8. Annoying Front Suspension Creak - Any Help??
  9. 2008 G37 on Eibachs major sag? or something else?
  10. Help with New Brakes
  11. Rear wheel poking out after curb
  12. VDC, slip and brake light on dashboard?
  13. Coilover Advice Wanted Please
  14. Akebono proact , hawk or project mu.
  15. Front Sway bar End Links from Moog
  16. Looking for suggestions on Rotors and Pads
  17. Strength of Steel for Toe Bolts?
  18. SPC Cam Bolt(72265) question
  19. What's the typical new pad thickness?
  20. H&R springs springs need help
  21. Brakes Kit for 2008 G37
  22. Why do I see so many references to coilovers with the G37x?
  23. Best brake pads?
  24. G35s and G37s RWD uses the same Eibach sway bar?
  25. Brake light while WOT
  26. Does g37s Coupe & Vert use the same brake pads?
  27. Are Akebono ACT888/905 fit for 2010 G37 Journey?
  28. G37x sedan w/ Hotchkis question for autorcross/track
  29. Stiff clutch/Bad chatter?
  30. clicking noise while pressing brake/clutch
  31. Going back to factory springs!!!
  32. Help - rear suspension failure
  33. HELP 2008 G37s rear brakes
  34. suspension question
  35. Stoptech Update
  36. Help Anyone Running Tein SS-P coilovers?
  37. Looking for some more ground clearance on swift springs
  38. Will sport suspension fit my Journey coupe?
  39. 350z coilovers on g37s coupe
  40. Help Lower front ball joint?
  41. Caliper torque value Akebono
  42. Review Energy Suspension diff bushings installed!!!!
  43. Brake Booster
  44. coilovers?
  45. Non-SPC camber kits?
  46. Need advice on lowering my 08 g37 coupe
  47. Help Eibach for the G37S Convertible?
  48. What does a ride height sensor do on our cars?
  49. Nismo 370 suspension on coupe?
  50. Help with a question about bagging
  51. Rear camber slightly off - is it worth fixing?
  52. Coilovers Questions
  53. Brake judder / splash shield / solution
  54. Powerstop brake kit?
  55. G37x Coupe - Springs
  56. Turn Rotors or buy new?
  57. VCD off/Brake/Slip light displayed
  58. Probably a repeated question about springs...
  59. is this a fair price?
  60. Alutec strut tower install
  61. Steering Ratio
  62. Possible to lower car with OE ride?
  63. swift springs
  64. Alignment woes
  65. bleeder valve cap questions
  66. Brake pads
  67. I need Some help with G37x Suspension Advise and Camber Advice
  68. G37x Coupe Springs - From an S coupe
  69. air suspension/coil for g37x coupe?
  70. Brake caliper decals
  71. Help G37x Coupe Suspension Suggestions Needed
  72. gtr r35 brake set up on g37.
  73. so who has bent a lower control arm?
  74. Help How long do the OEM struts last?
  75. Finally got my SPC installed
  76. brake noise from new brakes
  77. brake light comes on during launch?
  78. Why so many lowering suspensions for sale?
  79. Did Road America in the G. RSB from sport?
  80. G37x Coupe Springs
  81. Adjustable control arms
  82. Vibrant G37 Non-Sport Brake Paint Options
  83. Camber specs after alignment
  84. Sway Bar bracket broken
  85. Rotor and Pad Suggestion
  86. Wilwood BBK is on!
  87. Do XS coupe Springs fit on an X Coupe?
  88. Whats the story with my brakes?
  89. Sways vs Strut Brace or both?
  90. Bleeding both valves on the same caliper or just the outside valve?
  91. Do we really need a camber kit for TEIN lower spring?
  92. Help Need akebono hardware kit
  93. SPC camber kit quality
  94. Megan Racing Spring on an 08?
  95. Tein Street Flex Coilover, any good?
  96. Lowered car - rear passenger tire ware
  97. KW V3's?
  98. Hotchkis Front sway bar AWD
  99. Allignment, camber kit fixed
  100. H&R sport springs on G coupe!
