PDA
View Full Version : Brakes & Suspension
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41
  1. X sedan - Ideal height setup on C/O's?
  2. Should brake service cost more for sport model g37?
  3. Banjo Bolts
  4. Installing Camber kit on car with lowering Springs
  5. Getting her Wheels aligned and oil changed
  6. Difficulty of Lowering Springs/Camber Kit D.I.Y?
  7. Tein Flex Z on the way
  8. Need Rotor / Pad advice (coupe with Akebonos)
  9. Can anyone confirm this about rear suspension
  10. Alignment
  11. Need suggestions on coils for best ride
  12. Leak Around Bleeder Screw on Brakes
  13. Tips to remove stuck caliper pin/bolt?
  14. Lowering G37xS Coupe
  15. Question about SPC front arms
  16. 2009 Infiniti G37X frt. lower ball joints
  17. Rear Shock Tower
  18. Seized brake caliper?
  19. Megan Racing Springs
  20. Lowering front only
  21. Installing Cost
  22. G37x C/O install with a surprise - Day 1
  23. Help Slammed awd question
  24. Coilovers help!!! G37Xs Coupe
  25. 2009 G37s with sport package
  26. Sedan Shock Upgrades: Options?
  27. Can my friend use my stock suspension????
  28. Budgetish coilovers
  29. Newbie Question on Hotchkis Sway Bars
  30. reputable shops in north jersey!!
  31. Tanabe springs g37x coupe rear lower than front?
  32. Help Hotchkis Sway Bar with FI Catback Fitment Issue?
  33. G37 sport front brake pads
  34. Brake light flashes when shifting
  35. Coilovers for AWD coupe
  36. 370Z Rear Sway Bar
  37. Coupe wheels on my Sedan...camber looks off?
  38. Interesting findings...Coupe vs sedan brakes
  39. Understanding Sway Bars & End Links
  40. Best Replacement Brake Pads?
  41. Anyone with Koni Adjsutable w/ OEM springs?
  42. Sticking Caliper?
  43. Help identifying brakes to buy
  44. IPL braking creaking/groan noises
  45. G37xS Coilover and Spring install quote - $1100!?
  46. Bilstein B16 (PSS10) coilover suspension available soon for sedans!
  47. Anyone use Hawk quite slot rotors?
  48. 2008 G37S interchangeable camber suspension
  49. Best Springs for fronts only?
  50. Help Resurfacing dill and Slotted rotors
  51. Steering Feel with Hotchkis Sways
  52. BC Coilover dampening setting suggestions?
  53. Lowering a coupe
  54. Want to lower my Vert
  55. What does a suspension stay arm do?
  56. 2010 G37x coupe rotor diameter
  57. Looking for new (non lowering) springs....
  58. Help! BC BR strut rod diameter!
  59. Factory rwd sedan springs
  60. Help 2009 G37x coupe OEM rotor size
  61. Aftermarket brakes
  62. Steering Wheel shake
  63. OEM brake pad sounds
  64. D2 coilovers vs BC racing.
  65. 2010 Convertible Struts
  66. Swift springs
  67. Suspension Help
  68. Sway Bar
  69. Brakes upgrade nonsport for now
  70. Other alignment components besides camber kit?
  71. brake rotors uneven wear, rotor or pad?
  72. First time buying coilovers
  73. Looking for coilovers!!!
  74. What's the deal with these coils?
  75. Would I need realignment after installing my Eibach swaybars?
  76. Affordable Street Coilovers on an X.... any reviews?
  77. Clunk when going over bumps/holes
  78. How to prevent rusted-tight suspension bolts?
  79. Brake upgrade question
  80. G37x upper front strut bushing?
  81. Spring Rate Question
  82. Best coilover setup for close to factory ride
  83. Help Tein hi tech coils
  84. Help Aftermarket Rotors and Pads Squeal
  85. Alignment Spec with Eibach Springs
  86. Is this the sport/RWD beefier rear sway?
  87. Problem with STech springs sagging?
  88. Few air suspension install questions
  89. Just need SPC rear when lowering?
  90. Causes of camber BEFORE lowering?
  91. advice on brakes
  92. xS with RWD sway bar, to Hotchkis? Yes or No?
  93. Rear Toe Lockout Kit?
  94. Looking to buy a G37 Q's on lowering
  95. What is this noise?!
  96. Got Brake questions, Ask Ken from KNSBrakes.com!
  97. Best budget coilovers?
  98. Sway bars & ride quality
  99. Questions regarding sways/springs/spacers
  100. Front strut tower brace application
