- G-37 brake failure
- Cost for installing eibachs from Infiniti!?!?!?!?
- Service Manager from Infiniti regarding Eibach Price info and price of labor.
- RWD springs on AWD sedan question
- What is your SPC front control arm set to for caster adjustment?
- Which to install first?
- **** ARK PERFORMANCE INC: G37 DTP Coilover System Released. Made In Korea
- G37x owners, e-mail Tein if you want coilovers to be made by them
- Alignment spec with KWs and mild drop?
- Help Electronically controlled damping question
- Anyone have any experience with these brakes / this vendor?
- Installing BC coilovers on AWD G37, Any problems?
- Help Clicking noise possibly from suspension?
- Tanabe Sustec Pro-C Camber Kit needed?
- Help torque spec for suspension area?
- Paint wheel & brake
- steering wheel shakes when i take off from a stop
- H&R springs feedback?
- Hotchkis Sway bars for AWD G's
- We should put out heads together and make coilovers cabin adjustable
- G37XS GTSPEC Struts VS Hotchkis Sway bars
- Coilovers and alignment!
- Any other coilovers for the G37x sedan besides BC Racing?
- Aftermarket brake pads
- stiffness setting for k-sport coilovers?
- Rust Inside of The Wheel?
- Anyone here have experience with R1 Concept premium slotted/driller rotors?
- Newbie questions on lowering 6MT and Wheels
- Project Mu has their Piston Upgrade kit out for the Akebono brakes.
- best springs for my x?
- installed Coupe OEM rear spring on Vert
- Brake fluid and winter temperatures
- Drop on G37X Coupe
- General coilover question
- my alignment stats after lowering (pics)
- Brakes squeal when I reverse the car!
- Sedan Spring job without compressor...anyone?
- Terrible brake noise when reversing
- Lowering springs for the non-s.
- need front brake pad
- H&R Springs Questions and Help!!
- Non-S : Lowering Springs
- AWD is making modding difficult!
- Help Best Place to Purchase Eibach Pro Kit
- ugh...curbed wheel. need alignment?
- Dropping-101
- Noise under heavy braking
- Help front camber kit necessary?
- CVR Motorsports brake kit
- need help with brake pads?!?!
- Review Upgrades to my Suspension...
- rwd 37 sedan SPRINGS on 37x awd
- G sedan AWD BC coilover ** MUST READ**** UPDATED REG
- Lowering help needed for tomorrows alignment
- Another Eibach pro-kit ???
- Looking to Drop the X :)
- 370z springs on g37 sedan
- Alignment specs on Tanabe NF Springs
- TSB08046--Steeing Alingment on 08's covered under warranty?
- Do I need a camber kit?
- if your car is lowered on only spring,
- Need help before tomorrow morning
- Sways for your vert.
- Anyone selling g37x springs
- Running Coilovers... Open this!
- Cambers or no Cambers
- Eibach Pro Kit or Tein H Tech?
- Akebono help
- hotchkis X sway bars
- rear sway bar only
- Best place to buy H&R Springs for G37S?
- Endless Zeal Coilovers
- Hotchkis & Eibach ---- take the bigger bar from each?
- Brake light comes on
- Going for a drop...need information/person insights
- Will Tein S-Techs get lower?
- Installing used springs require springs to settle before alignment?
- Beshoff = awesomness
- Review MY G Ride On Tein Springs
- Eibach's on X coupe
- Help Attempted installing lowering springs
- Instructions for servicing non-sport brakes?
- best soloution for brake squeal
- Help ksports coilover, pictures of top pillow mount?
- Eibach pro springs worth it?
- Best brakes for everyday-city driving?
- Camber Kit + H&R Springs?
- TRAMLINING and wide tires..
- Going down on Eibach's.....stock 18's
- Calipers with stock rims
- Need Brake Rotor Recommendation
- Input on 370z Lowering Springs on the G
- finally got my rotors...
- Brake Rotor Groove
- sway bar general ride quality
- eibach sways
- yet another brake (design) question
- Best lowering choices for sedans
- 2009 G37x dropped on Eibach 6390.140 Review
- Brake Question
