- Painting GT spec strut brackets
- Dropping a Sport
- OEM Akebono BBK CCD
- about brembo
- Swift Coupe springs on Sedan RWD
- Brake pad suggestions for X sedans
- do any sedans come with the aero kit big brakes etc?
- Rear Upper Control arm Coupe
- Question concering the best vendor to buy rotors from....
- Help swaybar + alignment question
- '12 G37XS sedan no Akebono BBK?
- Swift Springs: Weird Drop - Front vs Rear?
- Tein Basic Coilover?
- Stock sport spring rates?
- Strut bar/takeda intake compatibility
- Front camber arms: Kinetix-type vs SPC-type
- Terrible Sounding Brakes
- Vibrate when coming to a stop
- Help Adjusting BC Coilovers...Quick Question
- Please post slammed or dumped G sedans on 19's
- iam new eibach or h&r
- Hotchkis sway bar install help please
- Help those will Stillen sways...what's your setting?
- Brake Pads...again
- Squeak after new suspension components. Any ideas?
- Help When braking from 60 to 70 mph
- Tein S Tech ??
- Help Will this Fit
- VDC & Slip lights are on
- Do the sport springs drop the car lower?
- Eibach springs front / H&R springs rear
- Finally got the vert dropped
- Anyone running the D2 coilovers?
- Eiibach Prokit + Spacers?
- cks coilovers?
- Springs
- Brake Upgrades for X coupe
- How do I know if my brake pads need replacing?
- Help Lighter Steering with Hotchkis Sways
- Cusco Strut Tower Brace Installed
- Help Megan Racing Coilover LP Series
- Camber Kit Needed For H&R Springs?
- OEM/Standard Brakes?
- Help - Torque Spec for G37x Strut Pinch Bolt
- Koni Yellows on a Sedan anyone actually have them?
- Help Another dissatisfied stoptech rotor owner
- Something new from KW: KW DDC ECU Coilover Kit
- Help Broke front SPC kit
- just installed the tein s tech springs!
- G37 brake pad shims
- What does everyone have their Rear Sways set at?
- KW coil over packaging (slightly OT)
- Brake Question on 2WD non-Sport Sedans
- Caliper paint
- Whats better? Caliper covers or Caliper paint?????
- Hotchkis sways: What p/n for '12 G37XS Sedan?
- Rotors and Pads
- lowering kit advice?
- KW coiloer intall time/cost
- WTB rims/springs
- Review Stance Coilovers
- Input on Kw V1 Coils for Mild Drop?
- Kw Eye Candy. Complete Build Journal coming soon
- Failed Akebono Install By Forum Member
- Tanabe rears with Eibach fronts?
- Brake Calipers 370Z do they fit a G37 sedan??
- Front rotors
- New member.. New G37.. quick sups. question
- Brake squeel on reverse
- Need advice on suspension/handling for 2012 G37xs
- Suggestion for a car besides G37 - budget 22K - 30K
- Hotchkis + West End=Roller Coaster Mode Engaged
- Time for a brake fluid flush?
- Buying brake stuff
- Sport brake lines?
- Hotchkis sway bar grease?
- What the ?&-! Ride height
- Better suspension for street use: Tein SS-P or Eibach + Koni Yellow?
- Suspension shop in South florida?
- Shop Quote To Install Eibach Pro Kit
- Help Stance Or BC V2?
- Do I need a camber kit?
- front camber bushings
- Help Alliance BBK rebuild kit
- Help VLSD Issues + no steering lock?
- Review = M7 Japan Coilovers =
- 2012 G37x AWD Sedan - Lowering Springs?
- Tein Coilover damping adjustment questions.
- Help AWD BBK Rotor size
- Swift springs...before and after
- Tokico Shocks
- Questions about coilovers!!!! D2
- Akebono ?
- Help Brake pads decision/input??
- Dat rust
- Pad and rotor recommendations
- Akebono for AWD..
- Springs
- Brake light coming on when flooring it?
- H&R Springs on AWD Coupe
