Leak Around Bleeder Screw on Brakes
So I recently installed akebono calipers on my coupe. Quick background, they were purchased used but the brakes had a couple thousand miles on them so they were basically new.
So I found out a couple weeks ago that the paint around the bleeder screw was peeling and saw that they were leaking. I ordered new ones and replaced them this past weekend. Before putting the wheels back on, I had my friend pump the brakes to see if any fluid leaked around the threads. Nothing, so put everything back together and I found that there is fluid around the rubber guard to the screw. Not as bad as before but there is still a leak.
Searched the forums and ideas range from not tight enough to needing a new caliper because of stripped threads. Just posting to see if anyone had fresh ideas/any input to help.
Thanks!
Thanks!
If you notice, the bottom of the bleeder screw is in the shape of a V. It is possible the seat in the caliper is deformed, thus not sealing properly. Could also be incorrect bleeder screws. How tight are you tightening them down? I use a small wrench (6"?) when doing mine, and just snug it down some. When you removed the original ones, were they deformed at all?
