First time buying coilovers
Old Feb 20, 2017 | 05:33 PM
Huaniitoo's Avatar
Huaniitoo
I have a daily 12 g37 sedan RWD and it's time to lower it. Any suggestions on comfort and good quality.?? I'm trying to stay under 1k
Old Feb 20, 2017 | 08:46 PM
Probably the best bang for your buck would be the Tein Basis Z coilovers, the dampers aren't adjustable but are set up for a ride that is more toward the comfort side with spring rates that are closer to OEM spring rates. These are very budget friendly at about $500 shipped. If you want adjustable dampers the Tein Flex Z can be had for about $800.
Old Feb 21, 2017 | 04:36 PM
Surfnazi's Avatar
Surfnazi
Spend a little more and get kw variants
Old Feb 21, 2017 | 08:02 PM
saywat?'s Avatar
saywat?
^ idk if spending $1.5k for kw1 or $3k for kw3 can be considered spending a little more lol
Old Feb 21, 2017 | 08:13 PM
HoldmyMouse's Avatar
HoldmyMouse
Unless you get it used. I've seen $1.5k for slightly used v3 which is a heck of a deal. KW is a quality brand so I wouldn't worry too much about getting it used.
Old Feb 23, 2017 | 05:28 AM
Surfnazi's Avatar
Surfnazi
Kw warranty is great
Old Feb 23, 2017 | 07:44 PM
Ape Factory's Avatar
Ape Factory
Flex Z all the way at that price point. Don't leave out the cost of an alignment and most likely aftermarket front upper arms and rear camber arms to get said alignment in spec.
