Few air suspension install questions
Old Feb 3, 2017 | 06:18 PM
ksmanuel's Avatar
ksmanuel
Working on installing my air suspension setup in my G37 sedan and have a couple of questions. Would appreciate some pics along with answers if anyone can chime in.
1) Where are you mounting your airlift/accuair control pads?
2) Where are you routing your airlines exiting the trunk to each wheel?
3) I have seen where people are using the passenger side of the firewall near the battery to get power wire to the trunk (for audio installs as well), is that the easiest way?
Thanks in advance
Old Feb 12, 2017 | 08:55 PM
Baby Jumpman's Avatar
Baby Jumpman
Didn't install my own but can help you out.
1-airlift remote is just on a cell phone mount for now but have seen many creative custom mounting spots.
2-there's a grommet in the bottom of the trunk I believe my shop used that to route the airlines. Drivers side you can use the fuel lines, passenger side you can use follow the same path, just use some hooks/ c clamps to keep it tidy.
3-I think it is. Had a little issue with water when he used the grommet on the drivers side, didn't use any sealant so it started to leak water when it rained. I relocated the wires to the spot you're talking about. Just use some silicone.
I'll get some pics for you when I get a chance. If you want something in particular shoot me a pm.
Old Feb 17, 2017 | 04:01 PM
slowguy27's Avatar
slowguy27
I don't have pictures but I did mine myself.
Like Bj said the remote can be mounted anywhere in the cabin, I velcro mine under the ashtray to the left of the shifter, real basic.
I ripped everything out trunk except for the BULL**** Bose amp and whatever that is on the other side. The grommet I used to get the lines out the trunk is located toward at the rear of the trunk in the middle, if you're standing at the trunk it will be right under you. There's some type of electrical cable going through there but that's the only thing. more than enough space to share with some airlines. The way I routed the lines to the front I went under the rear wheel lining around and under the side skirt to the front wheel lining and came out right where the strut is. Zip ties are your best friend just not to tight lol.
Power wise I added a second batt in the trunk to power everything.
Old Feb 17, 2017 | 04:02 PM
slowguy27's Avatar
slowguy27
Good luck buddy, hope to see pics when you're done.
Old Mar 16, 2017 | 08:38 PM
ksmanuel's Avatar
ksmanuel
thanks for info guys
posted a few pics of the car
https://www.myg37.com/forums/build-t...-air-ride.html
