brake rotors uneven wear, rotor or pad?
Hi, folks:
it has been raining here, and I have been out of the country for three weeks. I parked my car outside during these three weeks. When I came back from airport, I drove my car to gas station to get gas. When I did some quick eyeball inspection of my car, I found the the uneven wear on my left front brake rotor. See pics for details:
http://a64.tinypic.com/156g4ub.jpg
http://a67.tinypic.com/9u41z6.jpg
What's wrong with this rotor?
it seems the brake pad contacts half of the rotor deeper than the the other half.
About the rust on the rotor: I know you will common about it. I regret I replaced the stock brakes with these ProStop brakes. The rotors simply rust like it was born in junk yard, rather than from some assembly line. Only good thing is: they do not warp as the stocks did.
Thanks for tips!
Alex
it seems the brake pad contacts half of the rotor deeper than the the other half. About the rust on the rotor: I know you will common about it. I regret I replaced the stock brakes with these ProStop brakes. The rotors simply rust like it was born in junk yard, rather than from some assembly line. Only good thing is: they do not warp as the stocks did.
Thanks for tips!
Alex
If you are not getting vibration when braking, I wouldn't worry too much.
If you still worry, get a micrometer to check for unevenness and perhaps get the rotors turned and rebed the pads. I think at O'Reillys they charge $25 each rotor.
