G37s Sedan RWD Spacer/Alignment suggestions
Old Feb 3, 2020 | 05:10 PM
bellv83's Avatar
bellv83
hey guys I have a 12 S sedan RWD with swifts. Looking to flush the wheels, thinking 15mm spacers and get it aligned. Nothing crazy, just a mild over stock street alignment. Can anyone make some suggestions on the above?
Thanks
Old Feb 3, 2020 | 05:14 PM
That's how my car runs in the winter with the OEM 18" Sport Wheels, Swift Springs, 15mm spacer adapters and snow tires.
It's a big improvement in fitment over stock setup. With -2.0° of camber give or take, tires last maybe 15K miles, but if you're running summer performance rubber, that's all you can reasonably expect anyway.
Go for it!
Old Feb 3, 2020 | 05:20 PM
bellv83's Avatar
bellv83
My tires will dry rot before I wear them as I only drive 1-2k miles a year on it likely.
So stock settings but increase camber to -2
Thx
Old Feb 3, 2020 | 05:27 PM
Well, camber is going to be whatever it is with little adjustment unless you get adjustable control arms. My fronts are around -1.5° with OEM arms, but I've got rear camber arms so my rears are dialed in at -2.0°.
Years later, I'm still on the fence between 15mm and 20mm spacers, dropped with duckfeet & snows, but I bought 15mm, so that's that.
Old Feb 3, 2020 | 07:52 PM
bellv83's Avatar
bellv83
Meaning you think it needed 20 mm? I just don't wanna run into any rubbing issues, that's why I was considering 15. Do you have a pic of your car currently so I can gauge the flushness of the 15's
Old Feb 3, 2020 | 09:52 PM
Well, there's this thread here, duckfeet with 20mm up front and 25mm in the rear: https://www.myg37.com/forums/wheels-...g37-sedan.html
And my car with duckfeet, snows and 15mm spacers all around, from six years ago: https://www.myg37.com/forums/build-t...ml#post3844585
Old Feb 4, 2020 | 10:47 AM
bellv83's Avatar
bellv83
I see what you mean. 20mm looks a tad better but Ill prob go for 15 to maybe limit the stones getting thrown down the body.
Old Feb 4, 2020 | 12:00 PM
Yep, stones, debris and road tar... that's certainly a consideration. Good point.
Carfanatic
Dec 5, 2017 06:54 PM
ZenZiglar
Jul 16, 2013 12:24 PM
ErikM
Apr 1, 2013 03:10 PM
