Steering Rack leak
Old Oct 20, 2019 | 06:04 PM
Vanilla_Rice's Avatar
Vanilla_Rice
Steering Rack leak
370gt / g37 sedan 2009.. I appear to have a leak in my steering rack, pic attached. Anybody had this before ? My mechanic said he's replaced the o-ring before and it's still leaking?! It's not a big leak, but I'd prefer to fix the issue without replacing the steering rack.
Old Oct 21, 2019 | 04:31 AM
Said Amir's Avatar
Said Amir
Check my forum have the same issue, but don’t mess with it, just clean it up with some brake cleaner and leave it. If you take it out their is small springs inside of it, which can get misaligned in there and just mess the whole rack. That bolt is also used to tighten the steering feel, if you have a lot of play in your steering wheel but your wheels are not moving you can tighten it a bit, other than that wouldn’t mess with it.
Old Oct 21, 2019 | 05:12 AM
Surfnazi's Avatar
Surfnazi
High pressure line is leaking probably
Old Oct 21, 2019 | 11:31 AM
Conboss's Avatar
Conboss
I blew out my high pressure line a month ago, rack was weeping as well. Get under there and wash it, try and find out exactly where it's coming from. I hope it's the line TBH...
Old Oct 21, 2019 | 12:38 PM
slartibartfast's Avatar
slartibartfast
It's common for that bolt to weep on Gs. I assume you'll find the same issue on the 370Z if you check the Z34 boards.
Old Oct 21, 2019 | 04:08 PM
Vanilla_Rice
Thanks for the replies. Will clean and have further inspection. I did have heavy steering about 6 months ago, but at the time my steering fluid was a little low. Since top up the level hasn't dropped and my steering feels ok. Think I wont be messing with it for the mean time.
Trialmountain
Jan 14, 2019 07:02 PM
taimysho0
G37 Convertible
Mar 8, 2017 08:38 AM
G37XER
May 12, 2014 10:12 AM
rijc99
Nov 12, 2011 01:11 PM
