Help Vibration from 110km/h
Hi, I am new here and I’m from Spain so I apologize before for my bad English 😂
I bought a G37s 2012 not very common here like a year ago and I always had vibration in my steering wheel from left to right, I bough new rims JAPAN RACING JR20, 20”, 10 at the back and 8,5 at front, with 225/35/20 and 255/35/20. I also got HR springs on it and got my car alligned after that . Got my car with crazy vibrations even more than before... after balance my wheel lot of times where I bought the wheel and still the same I took it to another place and they told me the back wheels where bad from factory... I got that fixed and it got better I still have vibration in the steering wheel from 110km/h and I feel vibration in the car in my seat, pedals, and the car in general. It’s really frustrating I check wheel bearing and they look fine.
I even put back the OEM wheels and still the same... anybody with the same problem and got it solved? Thank you
Not totally remove , when I got it I got a click y noise when I go slow, and I seen here how to fix it it just need a bit of special grease in the part of the wheel not inside, I’m sorry I don’t know how it’s called in English 😂😂But it went , it’s possible I put it back wrong?? I didn’t pull it totally out
I had to replace my differential a few years back. so in the process, I changed the drive shaft out to a one piece aluminum one, and all the differential pushing to solid ones. installed the Z1 inserts into the subframe bushings. I end up with a high speed vibration that ruined all the positive effects. I researched driveshaft Pinion angle and found mine to be out of spec. I end up shimming the front differential mount about 3/8" and it corrected the problem. I have this car well over 100 mph plenty of time and haven't had any vibration. I noticed you never took your drive shaft out.
In this process I found there is a specific side of the universal joint that the nuts have to be on to seat properly. Mine were not . I have a theory that had something to do with my differential going bad in the first place . to long of story.
Now when I am checking for vibration after wheel balance and drive shaft balance I check driveshaft pinion angle also.
MW_G37xS
21
Oct 4, 2012 01:48 AM
brrrtpoypoy
14
Apr 13, 2008 06:52 PM
