Akebono & rotors
Old May 15, 2019 | 11:55 AM
Kpmikey808's Avatar
Kpmikey808
Akebono & rotors
Just bought some akebono calipers - I read a bunch off threads & would like some info from members please.
DIY - read to fold & flap dust shield for brakes & don’t cut it
disconnect the battery?
Do I need to bleed brakes after? Read Thru those threads too & best bleed kit ?
should I change brake fluid too?
what rotors do u recommend- I read eBay rotors & read reviews & peeps talked about cheap rotors & warped quickly
Mahalo ahead of time too 🤙
Old May 15, 2019 | 12:09 PM
Baadnewsburr's Avatar
Baadnewsburr
Honestly it doesn't really matter, but flap and fold may be better, just make sure the flaps don't interfere with the rotor
doesn't matter except for a certian type of brake bleed even then probably still doens't matter
Yes, you will have to bleed the new caliper, might as well flush the fluid... the Motive power bleed is very helpful if you work alone, otherwise just get somone to pump the brake, but either way you will need some hose from Home Depot and a receptacle to collect the old fluid in
I don't have experience with ebay rotors, but Centric "premium" rotors are popular and they make Stoptech ones too if you want slots or cross drilled but really anything with an E coating (i.e. not just paint) will ususalyl be very durable...tbh rotors don't really warp under normal conditions, usually people just don't bed in there pads and they get uneven deposits on the rotors which causes juddering ...you can always get super cheap rotors and spray paint the hubs with high heat paint especially if you are in a mild climate its a viable option if youre trying to save some money...if you're feeling spendy Z1 makes really nice 2 piece rotors which are a bargain for 2 piece rotors
Old May 15, 2019 | 01:32 PM
Said Amir's Avatar
Said Amir
Another tip to add to the top comment when bleeding the brakes first bleed the outer valve the one one with the Akebono sticker then bleed the inner. Since their is two bleeder valves on the calipers.
Old May 15, 2019 | 07:16 PM
And the brake bleed sequence Per fsm~passenger rear, driver front, driver rear, then lastly passenger front. X2 on just having a willing helper to press the brakes down as you bleed. The power bleeders are nice & work well but you can do the same thing for free and not much time w/ a helper (might bribe them w/a couple beers). And remember the bleeder screws are just a snug down, don't crank on those.
Old Aug 3, 2019 | 01:44 AM
Kpmikey808's Avatar
Kpmikey808
R1 concept cross drilled /slotted geomet carbon alloy rotors
Old Aug 3, 2019 | 02:25 AM
Kpmikey808's Avatar
Kpmikey808
Basically watched all the DIY videos on how to put on rotors & calipers
It’s better to buy rebuild kit before installing right?
All input is appreciated
triming/bending of dust shield
shorter banjo bolts but also saw someone use 1/4 crush nut washers I beleive to
shorten bolt length
i put anti seize on rotor
bleed brakes at the end
What can i do for spare tire to fit new akebonos
Old Aug 5, 2019 | 05:34 AM
Surfnazi's Avatar
Surfnazi
Spare tires that come with sport packaged cars fit
Old Aug 6, 2019 | 03:23 AM
Kpmikey808's Avatar
Kpmikey808
Thx u sir- where could I get one cheap? Do I know if a bigger rim would fit into spare tire space
Old Aug 6, 2019 | 06:05 AM
Surfnazi's Avatar
Surfnazi
Craigslist
Old Aug 6, 2019 | 02:37 PM
slartibartfast's Avatar
slartibartfast
Place a Want To Buy ad in our Classifieds, too.
Old Aug 10, 2019 | 05:23 AM
Surfnazi's Avatar
Surfnazi
Just go take slartibartfast when he isnt looking,if you're in dfw I have a few spares
Old Aug 10, 2019 | 03:33 PM
slartibartfast
Take me? Where? And I'm always looking. Except when I'm not.
G37Camel
Jun 17, 2016 02:59 PM
SoCal_G
Feb 19, 2016 08:54 AM
ImportPartsPro
Brakes/Suspension
202
Sep 2, 2015 12:34 PM
xSSv
May 20, 2012 01:06 PM
DPE G
Apr 26, 2012 10:06 PM
