Rotors warped after tire rotation?
Just had a routine service done on my G37x sedan (oil change, tire rotation). I have always had good luck with this dealership. I had the front and rear brakes changed about 12k miles ago, factory parts. After my tire rotation, I noticed a very slight pulsation in the rear when braking. I have heard of instances of this happening because the wheel bolts were put on way too tight. Has anyone else had this happen? I will say that the rear rotors were warped at 15k miles when we first bought the car, so it is possible they are just not lasting very long. I am hoping they are just wearing and the technician wasn't careless putting the bolts back on.
Rotors rarely warp any more. You could be sensing the first stages of uneven pad deposits, which commonly occurs on cars that are driven gently. Try performing the brake bedding procedure to see if that gets rid of the pulsation. It cost nothing more than a little extra gasoline.
more likely than the other other suggested scenarios, the shop that replaced the brakes didn't bother re-greasing the slide pins/didn't sufficiently grease the pads and they are binding now...these are commonly cut corners
Probably the tires. Did they get balanced when they were rotated? I have had tires that caused what you would think is warped rotors. Got rid of the tires got rid of the vibration. But you might be okay just getting them balanced.
njchen24
Jun 24, 2011 01:07 PM
