Brake Light Switch?
Brake Light Switch?
08 G37S Coupe
So woke up, had a dead battery, was hoping that was the issue. Get a new one in and notice my brake lights aren't going off. From what I've gathered it seems like its a brake light switch that has probably gone bad. I also noticed that when I push the start button, it immediately turns on, as if the brake were pressed, would that still be an issue caused by a brake light switch or could it be something else? I also intend on replacing the part myself so am curious if there is any How-To's around.
Any insight is highly appreciated
Ken
Ken
To clarify I have what appears to be two switches after a fork from the pedal, one is the brake light switch and I’m unsure what the other is and curious if it also needs replacing?
Stop light switch
Hi, apparently I’m having a similar issue and looks like I already fixed but just to be sure I’ve come here for advice.
what happen was I got my G37 6MT from my mechanic cuz I had a exhaust leak and it was triggering my o2 sensor and SES was coming on.
picked up the car took it for a test drive and no issues, all was fixed until, but later I went to grab a coffee and and noticed the 2 top led from the smaller circle in the tail lights were on, all the other off, coming home I felt the acceleration sluggish around 3k rpm, right after I got the Slip, VCD and ABS light on, so I got my scanner and got 1 fault at the abs, “stop light switch”
went to check it and everything seemed alright, just wiggle the wire and pressed a couple times the switch, erased the code, went for a short drive to test it, no more sluggishness and after locking the car all lights were off.
could it be just some kind of glitch or it’s a kinda of a warning that the switch is going bad??
thank you
thank you
Lt8Che
69
Apr 15, 2020 10:26 AM
Sam K
Jun 3, 2009 10:01 AM
VIP G
36
Jan 23, 2009 10:11 AM
