PDA
View Full Version : ECU Tuning / Dyno Data
Pages : [1] 2 3 4
  1. AdminTuning and Oscar On The Worlds Fastest 370z Record, Copy and Paste Tunes an
  2. New CARB Legal Performance Tune for us in CA
  3. Review Stillen Supercharged VQ37 tuning issue solved
  4. Help Repair or replace ECU
  5. Tuning Course
  6. 2013 G37x tune questions
  7. Help Tuning
  8. Dyno results
  9. Z1 Remote tune
  10. Ecu circuit diagram
  11. Tuning 7AT
  12. Ecutek bluetooth not working
  13. Tuning options
  14. AdminTuning Dyno Data/thoughts
  15. Do you get the most up to date ecu software when flashing?
  16. Making Some UpRev Log Analysis Tooling
  17. Help MAF voltage
  18. Acceleration Problems after EcuTek tune
  19. Any good tunes for the g37x sedan I'm new here
  20. Help ecutek tuner list
  21. Looking for ECU tune in San Diego
  22. Thoughts on new canned Z1 Ecutek tune
  23. Help UpRev tune remove
  24. Lean code P0174 after long idle period
  25. Parameters For Data-logging
  26. Thoughts on HPTuners?
  27. Underwhelming Dyno Tune?
  28. ECUTEK ProEcu kit questions
  29. E85 tune
  30. California Smog Tuned ECU
  31. Question about EcuTek tune and 93 octane
  32. Retune needed? From single exit to dual exit exhaust
  33. Moving from stock 2.5" intakes to custom 2.7" intakes
  34. Uprev verify rom id
  35. Will I hurt my car without a tune?
  36. Methanol Injection
  37. E85 tune help
  38. Tune Question - 91 or 93 Octane?
  39. Remote Tune Project
  40. Data Logging Questions
  41. Z1 mail in tune
  42. Has anyone ever tried these Thorton Chip Tuning Infiniti Performance Chip
  43. Detonation and big hesitation
  44. aftermarket fuel pressure reg on your G37
  45. Should I turbocharge or supercharge my g37?
  46. Need help with knock (logs available)
  47. Want some input about tuning (AdminTuning)
  48. Tuning advice
  49. Help Map changing with quick release
  50. How do I tune my g37 to get rid of the throttle lag?
  51. Tuner recommendation for CA
  52. Help Someone that knows how to properly tune vhr in Texas
  53. 2011 G37s Sedan 6mt dyno
  54. 2008 G37S Stock Dyno (Video)
  55. G37X Restricted Mods
  56. UPREV tune after Fast Intentions R-HFC install
  57. Torque application
  58. G37x Sedan Tune
  59. Tuner
  60. A/F ratio parameters
  61. SpecialtyZ Ecutek Programming kit
  62. EcuTek tune gains?
  63. Help ECU /program/tune
  64. G37 tune
  65. Anyway to Change the Rev Limiter in 6MT
  66. Would anyone read my logs?
  67. Help Shoot flames with stock cats?
  68. Sedan tuning question
  69. Car thinks I'm trying to 2-Step when giving it heavy throttle at low speed
  70. Help computer chip!
  71. Chassis Dyno Testing at Different Gear Ratios
  72. Tuning
  73. Rev limiter, two step , flames
  74. G37 sedan tune
  75. Stock 2010 g37x Dyno
  76. tuning
  77. Dyno Tune - Uprev
  78. Help with Dyno sheet! G37x
  79. Help Benchmark Numbers For OEM G37 - OBDII logging
  80. New Dyno !!
  81. New TCM or update?
  82. Dyno/ tune
  83. Ignition timing
  84. First Tune and Dyno
  85. Need help tuning
  86. Help Best way to dyno G37x
  87. anyone used moncef @ admintuning?
  88. Help Ecutek tune for 2010 6MT Sedan unavaiable?
  89. Tuner Review: Enthusiast Auto Care - Ecutek
  90. Tuning
  91. Nitrous install in the Boston area! uprev tune
  92. g37 ecutek tuner in IL
  93. Burble "POP" Map with Seb
  94. Help injector upgrade or stay stock
  95. Help Does my WHP seem low for a awd sedan?
  96. Is it worth having my car re-tuned?
  97. Anyone running the new release of Uprev?
  98. Does Z1 have a awd dyno?
  99. G37 full bolt on w/ SRI non CAI - Dallas, TX
  100. uprev Cable not deteted
