ECU Tuning / Dyno Data This subforum is specifically aimed at ECU Tuning reviews, questions, dyno charts, etc..
Sedan tuning question
Old Sep 4, 2019 | 08:22 PM
Jordan Ramon's Avatar
Jordan Ramon
I have a 2010 Sedan Journey and I was wondering what’s the better tune to go with between UpRev, admin or EcuTek, and why they prefer one over the other? I have HFC, Muffler delete and Takeda CAI.
Old Sep 5, 2019 | 12:20 AM
Psycho's Avatar
Psycho
Admin is a tuner not a tuning software.. I’d go with Ecutek though.
Old Sep 5, 2019 | 08:04 AM
RMB5190's Avatar
RMB5190
For an NA build, either works. For a boosted application, EcuTek seems to be the favorite. I believe it has more parameters to use when dialing in the tune but I'm not 100% sure.
UpRev, by itself, comes with burn tables for tuning. It makes dialing in the car very tricky for the tuner and can result in inconsistent power figures each pull. If you go this route, I'd recommend putting out the $100 extra for the ARC upgrade with the simplified timing tables. Instead of burn tables, the tuner then has access to the ECU's timing and it allows them to dial everything in.
I went with Uprev and am very happy with the numbers the car put down. It all depends on the tuner. Make sure you go to someone who knows what they are doing and is going to make sure the car retains a safe AFR throughout the pull.
Old Sep 5, 2019 | 07:21 PM
Jordan Ramon
thank you! I have a guy who does Uprev and ARC. The shop is Corr Performance in Louisiana. I read reviews and watched videos. I don’t know a whole lot and I’m goin to look more into it. I’m thinking of doing UpRev after most videos I watch. And What numbers did you put down?
Old Sep 6, 2019 | 12:08 PM
RMB5190's Avatar
RMB5190
315whp and 262ft. lb tq.
2012 G37x
Stillen G3 CAIs, ported OEM upper intake mani, Top speed y-back, ebay mid pipe, Circuit werks test pipes
Old Sep 6, 2019 | 04:05 PM
projectpanda13's Avatar
projectpanda13
2012 G37x
That's great power. I'm sad I'm rwd, and have two more mods on top of your list; EPS throttle bodies and ported lower manifold and only put out 310whp and 271 wtq on a dynojet. I dynoed 320whp at a different dynojet.
Old Sep 6, 2019 | 04:06 PM
Jordan Ramon
2012 G37x
Thank you! Did you feel a difference in the Y Pipe? I was going to order one from ISR
Old Sep 7, 2019 | 08:02 AM
RMB5190's Avatar
RMB5190
No, it's the least restrictive part of the system. It will change the tone pending your set-up though. Before test pipes (last mod before tune), the Y-pipe really deepened the tone and the car sounded perfect for my taste. Good volume for a daily and deep and burbly (technical term). After the test pipes, the car sounded like a bag of a$$. Tons of rasp and obnoxiously loud. Resonators installed and now the car has the proper tone and deepness to it with no rasp, that I like, but the volume isn't quite where it was. That's ok though; small compromise. I'd say it is the same volume as before the Y-pipe when I just had the Y-Back.
You'll truly feel a difference after the tune. The increase in power is one thing but in my case, the power delivery throughout the power band was the real surprise. It pulls after 3k RPM compared to before.
Old Sep 11, 2019 | 01:05 PM
latino914's Avatar
latino914
2012 G37x
The TS Y back came with a midpipe why did you get an eBay midpipe???
Old Sep 12, 2019 | 07:23 AM
RMB5190's Avatar
RMB5190
God da-.....I keep making that mistake. I have an eBay Y Pipe not a mid pipe
Old Sep 12, 2019 | 06:55 PM
Jordan Ramon
So you had the top Speed Y-Back exhaust?
Old Sep 13, 2019 | 12:45 PM
RMB5190's Avatar
RMB5190
Correct. Front to back:
Ported Intake Mani (DIY) > Circuit Werks TPs > Ebay Y pipe w/ Vibrant resonators welded in > Top Speed Y back
AMCDeac
Oct 6, 2012 07:45 PM
al-malkee
Middle East
Sep 18, 2012 11:56 AM
09gcoupe1
Dec 16, 2011 09:17 AM
cjc357
Jun 3, 2011 06:25 PM
aliiin
Feb 17, 2009 07:22 PM
