ECU Tuning / Dyno Data This subforum is specifically aimed at ECU Tuning reviews, questions, dyno charts, etc..
Help Best way to dyno G37x
Old Sep 5, 2018 | 02:52 PM
Awakence's Avatar
Awakence
Might be a stupid question but wondering if its better to dyno and tune the G37x (AWD) by pulling the awd fuse and just enabling the rwd for the dyno or actually using a AWD dyno and getting AWHP numbers. Also any tips or advice to tell the tuner on the dyno to get better numbers?
Old Sep 7, 2018 | 11:56 AM
RMB5190's Avatar
RMB5190
The AWD G37 is 100% RWD bias until slip is detected.
Old Sep 9, 2018 | 01:46 AM
Epiphany's Avatar
Epiphany
That's not correct. It's 25F/75R up to 12MPH then it's fully RWD until slip is detected. Ratio can also vary depending on slip.
Old Sep 10, 2018 | 07:38 AM
RMB5190's Avatar
RMB5190
You have a source for that? Infiniti states otherwise:
Old Sep 10, 2018 | 05:37 PM
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
Either find an AWD dyno, or detach the front driveshaft for a RWD dyno.
Old Sep 15, 2018 | 11:52 PM
Epiphany's Avatar
Epiphany
https://www.youtube.com/watch?v=P2kR8ASIiPs
I honestly can't find where I read it, but I did find this saying the same thing? https://www.myg37.com/forums/g37-sed...tem-split.html
Old Sep 17, 2018 | 09:01 AM
RMB5190's Avatar
RMB5190
I read that as well but none of it is supported and there's no evidence supporting any of those statements. Until I see that, I'm going with what the manufacturer states. Maybe when it's in 'snow' mode it makes that split? I don't know - again, I'd need to see some sort of evidence.
Old Sep 17, 2018 | 06:04 PM
Epiphany's Avatar
Epiphany
I found a review of a 2004 G35 that states all this, but Infiniti sure doesn't make info about the AWD system easy to find. https://www.motortrend.com/cars/infi...infiniti-g35x/
Old Sep 18, 2018 | 11:12 AM
RMB5190's Avatar
RMB5190
https://en.wikipedia.org/wiki/ATTESA
The X uses the ATTESA E-TS (First one on the list), from that paragraph...
'Drive to the rear wheels is constant via a tailshaft and rear differential, but drive to the front wheels is more complex by utilizing a transfer case on the rear of the transmission'
I want to draw attention to the word 'constant'. Having those two sources I believe it's safe to say, the G37x is 100% RWD until slip is detected. There is no evidence out there, that I've seen, that contradicts that besides internet rumors and water cooler talk.
We have the same AWD set-up as the R32 and R33 so I guess we have that going for us...
Old Sep 19, 2018 | 02:50 PM
Awakence's Avatar
Awakence
Never tested this but I have always thought that the power was split 60/40 (or 70/30 i forget) until a certain speed then it becomes rwd biased at 100% power. The Snow mode just prolongs that power split longer and restricts the throttle. The Altessa AWD system are different on the older skylines as its an older generations for the system.
Old Sep 19, 2018 | 02:54 PM
RMB5190's Avatar
RMB5190
We have the ATTESA E-TS. It's a 100% RWD bias system until 5% slip is detected. There's absolutely no split in the G37x. Snow mode limits throttle until 12 MPH. Even then, the car is 100% RWD until that 5% is detected.
Old Sep 19, 2018 | 08:26 PM
Epiphany's Avatar
Epiphany
I don't think the word constant means it's 100% RWD until slip is detected, it just means that there's always power going to the rear. As it stands there doesn't seem to be anything saying much either way about it. Again this is from a 2004 G35X, but that was also the ATTESA E-TS system. https://www.roadandtrack.com/new-car...infiniti-g35x/ . Part way down:
From a standing start, the G35x has a 25/75 front/rear torque split, but will immediately shift to 50/50 if the system senses wheel slip. Once the G35x is cruising, it shifts back to full-time rear drive to improve fuel economy. And fun. The G35x also features a Snow Mode, which locks the system (via a button on the center console) into a 50/50 split and reduces throttle sensitivity.
This site says the same thing: https://www.theautochannel.com/news/...12/170493.html . So I don't know where, but this info has definitely come from somewhere.
Old Sep 28, 2018 | 12:21 PM
zer099's Avatar
zer099
Is this a debate about if you can put a AWD G on a RWD dyno?
Do what he said. It sucks, but it's the truth. If you really want to roll the dice on how others thinks, reads, or believes the AWD system on our car works when you are about to strap your baby down and red-line it then I have some business propositions for you. I know when I flushed my tranny, all four wheels were turning. I know when I dynoed my car all four wheels were putting down power. I know I would never put an AWD car on a RWD dyno and risk any type of accident. But, those are all my opinions. You need to figure out what you would like to do then find a shop that will also comply. I doubt you will find a shop that will put your car on a RWD dyno without disconnecting the front shaft. Even if you electronically disable the ETS unit I do not know if I would roll those dice; again, my opinion.
I know Z1 here in GA will drop the front shaft to do a dyno.
Also, snow mode does more than throttle limit below 12mph (which it does do that, and pretty well). What's it do? No clue, but I can be doing 70 down the HWY and click that button and feel the torque split change for a second.
aria_blackG
34
Apr 18, 2011 01:30 PM
G37SBS
Jul 13, 2010 01:28 PM
UNCTYPE-S
Apr 7, 2010 10:34 PM
sebounet
Jun 28, 2009 09:32 AM
SlateBlue G
Jul 21, 2008 10:28 PM
