ECU Tuning / Dyno Data This subforum is specifically aimed at ECU Tuning reviews, questions, dyno charts, etc..
Will I hurt my car without a tune?
Old Apr 3, 2021 | 06:41 PM
Sgt.toast's Avatar
Sgt.toast
Question Will I hurt my car without a tune?
I would like to get HFC CAI and do a muffler delete, however currently only have a budget of 500 or so dollars. Trying to add mods as I get more money. Can I install these mods before a tune and not damage my car? Or do I need to save up to do all of the work at once?
of course I understand that I will not be getting as much performance without a tune, but feel like it would be a waste of money to get a tune kit and tune, then having to retune after installing the mods.
Old Apr 4, 2021 | 09:12 AM
RMB5190's Avatar
RMB5190
You should be fine but depends on the CAI you're going with. Stillen or Takeda and you won't need one; go with Admin and you do.
With $500, I wouldn't even worry about HFCs and CAIs at this point. Go muffler delete and a sway F/R sway bar upgrade. Those two will give you a little more exhaust growl and tighten up the handling.
Do you have a 6sp? If so, clutch spring upgrade would be worth checking into.
Old Apr 7, 2021 | 02:15 PM
ryanwhite74115's Avatar
ryanwhite74115
I have full z1 cold air intakes, z1 high flow cats (although they might as well be test pipes given the 100 cell cat), and full custom exhaust. No tune. I throw a CEL code about once every 1-3 months. Other than that...absolutely no problems.
Old Dec 3, 2021 | 08:17 AM
BULL's Avatar
BULL
Moderador
Get you some spacers for the 02s and some 80 grit sand paper for your flanges.
Put your CAIs and HFCs on and save up your money for a tune.
The spacers will increase the possibilities of avoiding a CEL
You should invest in a BT OBD reader and with Torque and OBD fusion you could check your AFRs
So pay attention to your AFRs and as long as it's not too lean you'll be fine until your tune.
If you have not done it yet, I like to run new plugs prior to a tune. Consider this since these plugs are $8+ ea
Pass by your local muffler shop and ask for some quotes, muffler deletes sound horrible in my opinion, a muffler shop exhaust should look decent and sound 10x better than a delete.
Old Jan 15, 2022 | 10:17 PM
TheDigitz's Avatar
TheDigitz
Hey Bull - mind sharing a bit more detail about the above advice? Not sure what you are referring to and I'm intrigued. Thanks!
Old Jun 24, 2022 | 11:46 PM
JME377's Avatar
JME377
what kind of hp and track times do your car in this setup do?
midnight37
Apr 27, 2020 08:56 PM
Wyldfyer
Intake and Exhaust
14
Nov 21, 2017 04:22 AM
G37_4DR
Apr 17, 2017 09:06 PM
sask83
Jun 15, 2014 03:50 PM
Infinite.G
20
Aug 22, 2010 01:44 PM
