PDA
View Full Version : General Tech Questions
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. Burning smell?? (2013 G sedan)
  2. Help New member with p0113 and p2a03
  3. P0456
  4. G37S Coupe battery on and off
  5. Help - Horn Honking When Parked (6 quick beeps in a sec)
  6. Routine maintenance
  7. Screw Extractor Size?
  8. Does it sound healthy? Is that sound normal?
  9. G37s Maintenance Cost
  10. Fuel Pump Relay Location
  11. Two oil/filter life meters?
  12. screeching at high rpm
  13. Need Help: Read Shocks, Ser
  14. Steering rack covered by extended warranty?
  15. Gas Cap Snap Off
  16. trouble shooting passenger window
  17. window problem
  18. OBD and Clock not working... Help pls!
  19. Life of oem brake pads
  20. Wheel bearing replacement
  21. Wc 15.24 by the vin?
  22. Car start up is fine, dying out when I put in gear, clunking noise follows
  23. Engine Dying
  24. Jacking from pinch welds
  25. Stuck secondary hood latch
  26. Windshield washer reservoir screw causing a rattle
  27. Unlock/Lock
  28. Location of starter in a 2008 G37
  29. Transmission Flush G37 CoupeS
  30. Spark plugs and coils for g37 coupe
  31. 2008 g37s A/T acting up some sorta glitch?
  32. 2009 Coupe - Rear Bushing/Subframe Leak
  33. Part name / place to buy?
  34. is my key fob dying?
  35. **Box of rocks coming out from under my coupe??
  36. Gas gauge is inconsistent
  37. My status screen showing high gas consumption.
  38. Oil Filter Size matter?
  39. Odd Idle issue
  40. Group 24F and 34R battery for 2008 G37 Coupe
  41. Door handle unlock/locking beep sound
  42. Help P0420 Catalyst System Efficiency Below Threshold (Bank 1)
  43. Installed a GROM VLine kit, now have aux airbag problem...
  44. Fuse Box IPDM E/R access
  45. Fuel Question
  46. Help Knocking coming from under the car
  47. Help Need help with streaming audio from iPhone
  48. I'm assuming this isn't normal?
  49. Help Jerky transmission, wheel hop.
  50. Muffler size
  51. Windshield Wiper
  52. how do you tell what sub model your g37 is?
  53. Battery issue, car won't turn on and shuts off
  54. Seatbelt SRS wiring
  55. BCM Sleep and battery drain
  56. Help Trustworthy Service in Northern New England
  57. Fuel economy steadily decreasing.
  58. How many miles do you get on a full/half tank of gas?
  59. Steering rack
  60. Slow reverse and I believe battery problem
  61. Engine oil dipstick reads above H?
  62. Battery Terminal Nut Thread Size
  63. 2010 g37 problem with the whole car
  64. 2010 g37 problem with the whole car
  65. 2010 g37 problem with the whole car
  66. HELP Automatic shift knob not locking in place, shifting into neutral (video)
  67. trunk release problem
  68. How to prevent wheel rotating while trying to remove axle nut?
  69. Shutting on and off!!
  70. Worlds most expensive creeper
  71. Screeching sound on start-up with vehicle. Occurred after it snowed.
  72. Help Cold air during idle
  73. How fast will battery die out with this ignition on
  74. Gas light?
  75. Exide Battery Home Depot Experience
  76. Battery cover purpose?
  77. Help Weird charging issue! I need input plz
  78. Help Oil Leak? Changing the oil and noticed this.....
  79. High-mileage maintenance schedule?
  80. Help Shift lock and other problems post OBDII reset
  81. Throttle lag
  82. Help Problems on cold weather.
  83. Is the 33,750 maintenance necessary?
  84. Traction Control Light
  85. 0w20 Synthetic a Standard Substitute in G37 ???
  86. Sunroof Stuck at Tilt Position G37 2008 coupe
  87. Cabin Air Filter Replacement
  88. G37x won't start
  89. how long for power steering fluid to turn 'black'
  90. G37x Rattle/knocking sound
  91. Battery Tender for the G37 Coupe
  92. Offset steering wheel
  93. G37 washer fluid sensor?
  94. Help Rear diff. Fluid?
  95. Help 2009 7 speed trans fluid change
  96. battery drain
  97. Help Overheating
  98. Your take on permanent dtc codes
  99. Engine Start
  100. How to diagnose a bad torque converter
