PDA
View Full Version : General Tech Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22
  1. OEM Cabin filter replacement . . .
  2. brakes
  3. Tuning screw up
  4. catalytic converter recommendation?
  5. traveling with loaner car
  6. Spare tire maintenance
  7. Help A/C condenser problem
  8. Replace 100% of ATF . . .
  9. Passenger side auto window not working
  10. Help Wheel bearing and spacers
  11. Gas Cap Attachment?
  12. Help Ecu reset problem
  13. Power Steering fluid change
  14. Terminal Pin Tool
  15. wire hanging under car?
  16. Newbie question - foglight bulb for 2010 sedan?
  17. Help SES after disconnecting battery/BCM
  18. Ge7 drip rail removal
  19. Transmission Flushed with K6600. What is this stuff?
  20. Help Cruise Control turns on by itself and "set" blinks
  21. Squeak Under acceleration
  22. Gas saving tips. got it from FB group share.
  23. Car not starting sometimes
  24. GOT THIS PROB? G37s - Service Engine light on - Idling 1000 rpm - NO CURE?
  25. Upper and lower rad hose replacement
  26. Help New HELP!!!
  27. Anybody get exhaust smell right after hard acceleration?
  28. Replacing the Bezel Steering wheel Trim
  29. 2009 G37S shifting issue
  30. 2010 G37x Clicking noise
  31. Basic longevity mod info for track days and autocross
  32. Help Power steering problem
  33. Does SES equal code??
  34. Popping/jumping from driveline when first turning in wet/cold weather
  35. Pennzoil Ultra, $10 off or almost FREE
  36. Has anyone cleaned their maf sensors before?
  37. Help 08 G37s Adaptive Front lighting System (AFS) only works on one side ?
  38. Some things I cannot figure out on my New G and cannot find in the manual
  39. Help Borrowed G37 Won't Start!
  40. Help Leaving the key without killing the battery
  41. Help Post SeaFoam Experience
  42. Yellowish-Green Fluid???
  43. Switching from synthetic/dio blend oil to full synthetic?
  44. Differential sludge?
  45. Help -Snowing
  46. Emission on a 2011
  47. Help Help, finding some OEM parts
  48. Help creeking noise on inclines from rear inside the car
  49. Seat Belt Light Flashing.
  50. My battery was drained to FLAT, what are the chances its still good?
  51. Limp mode, work order codes
  52. Help Rev limit, violent jerking
  53. New G37S Questions - oil/tranny
  54. Wiper & Washer
  55. Help VDC OFF and SLIP lights reset
  56. Help A/C Recharged But Still Doesnt Work
  57. Transmission & Differential Fluid change
  58. Review First Snowfall driving impressions- hakk 7's 09 g37x
  59. RPM dip at idle and rumble after long drive.
  60. Can I get my oil filter change elsewhere ?
  61. Help Engine packaging for shipping
  62. Any Damage to Engine by using 5W-20?
  63. G37 stalls while driving on highway
  64. Accidentally put HIGH MILAGE 5W-30 Mobil 1 in. Am I hurting anyting?
  65. Dropped in Engine Compartment
  66. Totaled??
  67. Help Removing Oil filter problems
  68. Help Broken Endlink?
  69. Multiple cylinder misfire...
  70. Help Sedan vs. Coupe cabin filters
  71. Help No Heat...
  72. Weird RPM drop
  73. Bushings
  74. Car does not start
  75. HVAC switching on its own
  76. Squeaking in the rear when I hit bumps
  77. does any one know how bright is ...
  78. Help electrical gremlins after center console disassembly
  79. Windshield Wiper Sprayer problem
  80. 100,000 mile service? Anything special?
  81. 2008 G37 coupe oil??
  82. Help Hard Start Question
  83. license plate ligth bracket
  84. Engine RPM 3K@80MPH - Really???
  85. FSM reviewed, Did I forget anything else? Please instruct me
  86. What kind of Oil & Filter are you using?
  87. quick synthetic question
  88. parking position
  89. steering wheel cruise control question
  90. Strange window behavior
  91. Help Faulty Fuel meter reading
  92. Amsoil vs Mobil 1/Penns oils ?
  93. Oiled Spark Plug and Heat Damage?
  94. leak near rear differential
  95. What should I look out for?
  96. Help Extended Warranty
  97. Help OBD Code P01D0?
  98. oil change question
  99. key fob question
  100. Hood not latching.
