PDA
View Full Version : General Tech Questions
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. Coolant Drain/Refill - Parts to Replace?
  2. True Level - getting car perfectly level for trans fluid measurments
  3. Help with O2 sensor issues
  4. Arc-angel LiFePO4
  5. Help Cabin Air Intake Location
  6. Help Upstream Oxygen sensors
  7. Help Light on cluster gauge blown?
  8. Help 4 mechanics couldn’t fix it
  9. 2008 G37 "restarts" while driving
  10. Beeping Coming From Engine
  11. Help Intelligent key warning light and steering wheel lock
  12. Help 2011 G37x Coupe Whistling Sounds at 100KM/H Speeds
  13. Heated/Cooled Seat on P/S Comes on for 7 sec Then Goes off
  14. Need location of A/C Compressor Relay
  15. HELP. Possible Radiator leak or overfill
  16. Poor MPG after 100k mile service
  17. New here with a concern
  18. Oil Filter Recommendation?
  19. Help accidentally put transmission fluid in power steering
  20. Help Ac pressure high
  21. Help G25 2012
  22. 2008 g37
  23. Transmission problem?
  24. suddenly completely dead, but battery at 12.75
  25. Help Odd Water Noise Only On Acceleration from Stop
  26. Help A/c only works when car it's cold
  27. HELP! URGENT! Window won't roll up!!
  28. Anyone know what this is and does?
  29. Maintenance Mods?
  30. Help G37 Annoying Click with Swaying
  31. Car won’t start, All electric shuts off while driving
  32. Help The “Other” Clutch Safety Switch
  33. Horn and PSa system for G37
  34. How to check coolant if it is too low?
  35. Help Horn no longer sounds when setting alarm
  36. Recomendations for air filter?
  37. Decarbonizing Service
  38. Fluid Leak? Looking for Advice
  39. Put an aftermarket seat in, Power mirrors don't work
  40. 2010 Infiniti G37s Coupe Manual - 100k+ Suggested Routine Maintenance/Problems
  41. Key fob
  42. Need help/advise for the AC problem
  43. Air Conditioning Blew Up
  44. Nissan Transmission Fluid - Matic-J vs Matic-S
  45. Bad ECM
  46. Help Tomei exhaust
  47. Help Seeking part #: front bumper retention (side of bumper/fender, below headlight)
  48. Maintenance Schedule?
  49. 70k mile service. What needs to be done?
  50. Help Found this in my glovebox...WTH is it?
  51. Battery dies while driving
  52. Seatbelt solutions for aftermarket seats?
  53. Front Right Rubbing/Grind @ 80-90mph?
  54. Help Is it worth getting my car Tuned
  55. Front air bag sensor pigtail wire colors
  56. G-37 x Infiniti
  57. Help with brakes!!!
  58. 2009 g37 codes
  59. Faulty fuel pump/relay after altering fuses
  60. Replacement OEM Wiper Blades
  61. Fluid info
  62. Automatic Transmission sedan rear diff
  63. Anyone Replaced Backup Sensors?
  64. Recommended maintenance '08 37s 5AT
  65. G37 Coupe Oil Change
  66. Disable/Remove EDR
  67. Help Where is the sunroof drain on G37 ???
  68. Help Trunk Chrome Button Don't Work
  69. Rattling Noise
  70. Help Rear passenger window won't reset/relearn
  71. Water gets rid of squeak?
  72. rhythmic noise when idling
  73. Picky key fob or bad starter?
  74. Alternator pulley?
  75. Help Give it to me straight, how difficult is it to replace the alternator?
  76. Changing tensioner pulley without completely removing belt?
  77. Help Where does this wire go?
  78. Weird sound that randomly comes and goes
  79. Car Stuck in Park and Unresponsive Gauge Cluster (Code: U1000 and P0463)
  80. Anyone see this Infiniti fuse box test (Video) ??
  81. NE1 order body parts from this vendor? IPL bumper for example
  82. Where is the best price to buy sparkplugs
  83. Door Actuator, ECUTEK Tune, Dealer/Warranty... Help?
  84. Correct Car Battery for 2010 G37x
  85. Noise when i lift the gas
  86. Battery dying, which to get as replacement?
  87. Help Rear Seat Belt Locked In Stowed Position
  88. 2013 G37x Windows Rattling
  89. Green Crust - Coolant
  90. Battery Booster Cables REVERSED While Boosting G37
  91. Pax side window switches do not work
  92. Is there a website to view all options car was ordered with?
  93. Check battery and brake light keep coming on
  94. confusing g37x battery issue!
  95. Help Engine code: P0456
  96. Dome lights flickering when off
  97. Help How much do these parts typically cost?
  98. Help Exhaust hardware size help
  99. Help Terminology request
  100. Great Deal on OEM Spark Plugs
