View Full Version : General Tech Questions
- Found a video bashing admintuning, read the comments post your thoughts
- Help G not starting
- Help P0300 random misfire
- AC Blower motor?
- Help P0106 MAP sensor issue. (Can’t pass smog)
- Help Replaced coils and sparkplugs
- Help Condesation on spark plugs
- Help U0415, B2562, B2617 codes G37S 6MT coupe
- Help Coolant leaking in rear of engine bay, no white smoke or milky oil
- Automatic Transmission lurch in 1st gear
- Valve Lifter = New Engine?
- Help Squeaking noise while turning/going over bumps
- Alternative Jacking Points?
- Rear differential bushing hatred
- Help Engine blowing air and won’t start
- Help Can’t identify what’s wrong exactly
- Fuel Rail Electrical Connection Problems
- Cleaning Inside Engine tips
- Avoiding VDC and SLIP light with clock spring replacement
- Help! Rear License Plate Screws Keep Spinning
- Help Intermittent Cam Position Sensor code
- Ported Upper Plenum - How's it Look?
- Is UpRev the only Tuning option?
- Thanksgiving Sale - Infiniti Dealership Parts - Online Only
- Help 91, 95 or 98 Octane in the UAE
- Help 2015 infinti q60s streering wheel stuck and missing parts
- Help Best Short-Ram intake system?
- Help Engine Bay Dress Up Bolts Caused Severe Electrical Failures
- Help Test pipe question
- Will coupe visors fit a sedan?
- 6MT question, is this normal?
- Help Tuner shops in Chicago?
- Help Broken Muffler Hanger Bracket
- Mobil Super Synthetic + OEM M56 Filter?
- Help G37xS Coupe Squeaking
- Help Keeps dying on me
- Help Water on Drivers Floor under carpet floor mat :(
- Help Alternator? TLDR; Battery/Brake Light, gas pedal cuts out
- ethanol vs. non ethanol gas?
- 2008 journey coupe vs 2012 journey coupe
- Help Ess fuse?
- Help Snapped rear subframe stud
- Help Low Profile Jack Recommendation
- Cut flap off bottom undercover, problem?
- Electronics Column Cylinder?
- Help Driver side headlight and turn signal
- Help AC won’t blow air, blower motor was replaced last year with new unused motor
- Help Transmission slips
- Help Motor mount bushing
- Help 12v/cigg power and climate controls
- Rear Side Damage... What to do?
- Help 2011 G37 coupe gas cap replacement
- Is My Power Steering Pump Failing?
- Low oil pressure after new gasket HELP!
- Help Engine Ticking/Knocking?
- Analog Clock and keyless lock ‘beep’ not working
- Help G37 coupe with Power issues
- Rattling sound from transmission
- Help Paddle shifter plug
- Gas air pressure while opening the fuel tank
- Anyone has any idea what is causing these sounds?
- Need to decide between an aluminum and a steel strut bar
- Code B1134 or B1134-00 need help
- Car starts but I cannot enter ACC mode
- Throttle Body Cleaning Caused SES, VDC, SLIP Lights
- Drain plug came out
- Help Overheating
- Help Infiniti G37S Won’t Start
- G37s Sedan Airbag Light
- G37x Squeak while driving - Driving me insane
- Help Window roll down response is slow
- VIN Decoder
- Change PS fluid reservoir hoses
- Help Is replacing the clutch master cylinder a must when doing the slave?
- '09 G37x coupe Intelligent key warning light on in park only
- Need some help with OBD codes
- Blue Long Life Coolant - Expiration
- Help P0462 and gas gauge reading error
- AWS Maintennace
- Question about transmission fluid change
- Help No Headlights After New Battery
- Help Engine Performance Issue 2013 IPL Vert
- Help Question about coolant ratio change and capacity
- Help 2010 G37x limp mode
- Transmission Filter Question
- Help 08 G37 RWD 5AT Stalled
- G37 high flow cats
- R8 Coil pack for G37?
- Help Transmission Pan/Filter Bolt Tightening Sequence
- P0304, P0732, P0615, C1109 error codes
- Help G37 rattle while acceleration
- Does your fuel pump hiss too? Snakes in backseat?
- Help Bad Ballast?
- Car Not starting
- Help Rusty lower Steering u-joint
- Help Ac compressor broken
- Help Door locks lock immediately after pressing unlock
- Help Belt size for AC compressor delete?
- G37s rear deck subwoofer sounds blown
- 2013 g37x lack of power on start up
