- Help Stillen gen 3 owners
- serpintine belt
- Props to Richard @ Gunn Infiniti service
- Magnetic Drain Plugs??
- Help Gas Cap = Service Engine Light?
- Mobil 1 UOA
- Help Part # request.
- Help Part number request
- Evaporator Core
- 12k maintanence.
- headlight problem
- suspension questions....
- 2010 Nav system differences vs. 2007-2009
- Water leak under floor mats
- Help Auto Transmission
- Help Lights
- Help Outside Chime When Locking (not horn)
- Help transmission jerking when downshifting in AT
- what is this warning light?!
- Where can I find Pennzoil Platinum 5 quarts jug?
- Help Wind Shield
- Exhaust noise??
- Help VLEDs H1 conversion installation
- keep AC on recirculate?
- Help Whats the size and thread pitch of the end link nut for rear sway bar??? ASAP
- lights come on when i punch it
- Help Six Months and 1700 miles later
- hood latch issue
- Help MT or AT in my case ? (want your opinions)
- Weird sound on start up
- Parked by G, turned off car, fog lights decided to stay on
- G37 Won't start
- Help Navigation reset
- Factory Service Manual - FSM
- Help rear noise inside car
- d.i. y. maintenance?
- What does the Exclamation Mark mean?
- Help cant find tsb on ester oil replacement for ticking noise
- Noise coming from what seems to be in the rear of the car?
- Help just a quick question regarding red optima battery
- Non OEM Versus OEM filters
- Question about the 7AT
- AC smell
- Castrol Edge Rebate
- Help Suggestions for Floor jack and stands or maybe even ramps
- Just Had Nissan do an oil change
- Gas stabilizer
- Whats best for the car?
- Got my UOA from blackstone labs, Now what the **** do I do with it?
- Ester Oil Change Intervals?
- How much for 30k service?
- Got into a bad accident, need your help
- Help Don't have time to take it to the dealer for 15k
- Why didn't maintenance reminder pop up?
- Folding rear seats
- Help Bottomed out --> Svc. Engine light appears, thoughts?
- Teach me how to drive my 6MT
- Notification on radio screen
- Infiniti brand Oil filter?
- Best syn oil and filter
- Leaving the G for a Year (advice)
- Grounding Kits and Services
- Help G37 Sedan hood is loose
- Noise from steering wheel?
- Tranny Oil (Eneos)
- Power Steering Problem
- BG Total Deposit Control Kit?
- Help Warranty Question
- trunk wont open!?
- Help G37x Coupe Downshifting
- Oil change at 3000 miles or 3750 miles?
- 370Z filter in a G37?
- Performance or visual??
- valve ticking issue with 2009 g37s!
- Help Can anybody in South Florida help me install my filters?
- Help ECU Problem?
- Help 2009 g37xs Sedan general maintenance question
- Help What size hex key for MT and rear differential fill/drain plugs?
- Better power after break-in??
- Is it safe to switch from Mobil 1 to Nissan Ester and vice versa?
- Jack Stand Points...Where is it??
- Help Few Quirks with the G
- Help 15,000 mile service
- Help check engine + dealer
- G37S Smart Key
- Help Wierd problem, Odometer not counting
- Rhino Ramp question
- slight squeaking noise from engine.
- Dropped car off at dealer today..
- Survey about oil consumption
- should the radiator jiggle at all?
- Jack stand points
- Mobil 1
- Maintenance plan i n bay area, CA - premium or schedule 2
- Help After berk HFCs install SES light thrown, p1168 & p0051
- How to
- First Year done - Maintenance Required?
- Does the G have built in maintenance reminders?
- O2 sensor extenders
- oil ?
