PDA
View Full Version : General Tech Questions
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. Rear window 1/2” lower than front window
  2. Help A/F Ratio Engine Harness Wiring Colors Please (Driver Side)
  3. g37 steering locked and start button stuck on locked
  4. Help Interchangeable parts 2011 to 2008
  5. CMAK/Flywheel/Clutch/and more) installation parts? Anything else to consider?
  6. Help Fuel Pressure Issue / Question
  7. Help Are any of these a/c compressors from rock auto any good?
  8. Help Tail lights or brake lights on after car was off. Drained battery
  9. Help Radiator AC cooling fan not coming on
  10. Cold Air Intake. Tune for better gas mileage?
  11. Help Flashed Car Tune, will crank but won’t start
  12. Help ABS codes
  13. AC blowing hot
  14. Help 2013 G37 AT Stalling in drive idle or reverse idle
  15. Help Rusty front cross member. Safe to drive temporarily?
  16. Windows and AC only working intermittently
  17. Modding your Steering Shroud for Paddle Shifters
  18. Help Rattling metal sound after clutch is replaced
  19. Help 2009 G37 sedan auto engine swap issue
  20. Help Problem with a warning light and seat heating/vent
  21. G37S Coupe RWD steering rack differences
  22. Need help with hood latch line mount
  23. Is this a real and/or serious steering rack leak?
  24. Help Power Seat Recline Won't Work
  25. IPDM Replacement
  26. Help Automatic Drive Positioner Problem (ADP) + How do I take off this panel?
  27. Front End Rattle and Belt Squeal
  28. Help A/C isnt working, only "works" when driving
  29. 2006 G35 VHR swapped
  30. Upper hose coolant reservoir tank
  31. Help 2009 g37x coupe
  32. Help All dash lights 2011 g37x auto
  33. anyone try water wetter/vp cooldown
  34. Help Looking to flush my PS fluid, any threads / help on getting this done?
  35. Transfer case fluid
  36. Hydraulic lines from rack to pump HELP!
  37. Help G37x backlight on climate control, radio, nav, and gear selector not working
  38. Help Idle drops, shudders when stopped
  39. 2010 G37X Black Cluster
  40. Heavy Door Issue 2012 G37 xs Coupe
  41. Help Reset HVAC Controller
  42. Coolant leak
  43. Help Alternator Issues?
  44. Help Overheating issues
  45. Help 2011 g37x sedan (remote start question)
  46. Radiator questions
  47. Yellow fluid leaking from the driver side CV shaft
  48. Engine Noise once I put it into drive
  49. Help Does this mean my bcm is fried or can it be saved
  50. Is this little brace important?
  51. Help Rattle when accelerating
  52. Help Vvel synchronization
  53. AC working intermittently
  54. Anyone try Rotella 5W-40 motor oil?
  55. Code u0101 (Lost Com w/ TCM)
  56. Disconnecting wiring harness
  57. Help Active check p0451 code
  58. Application to find car parts?
  59. Help G37x sedan Won't Start but Fans Stay On Max
  60. How to get help with a problem
  61. My quest to make my car quiet again
  62. Middle Infotainment doesn’t work whatsoever
  63. Engine falls flat on its face after 3K
  64. Fuel Pump Replacement
  65. Z1 Cold Air Intakes - Remove Front bumper?
  66. Help Need Help Fix Codes On 2009 G37 Sport Coupe
  67. Help Rear Left ABS malfunctional, now my slip/brake light is coming on sometimes
  68. 2011 g37x AWD lights on
  69. Do I have a bad BCM module? 2009 G37
  70. AC blowing hot air
  71. Help 2013 G37 power lock issue
  72. Help Windows aren’t working anymore
  73. Coolant leak under driver side throttle body
  74. Help G37 Locked with Red Security Indicator Flashing
  75. P0447 Code
  76. Help KEY ID incorrect
  77. Help 3” intakes on g37 coupe pass inspection?
  78. Help Please help alternator
  79. Help Airbag light
  80. Help Fusible Link Q’s
  81. Help Yet another fuel gauge post: replaced AC amplifier and level is still incorrect
  82. Help rough idle, lean fuel code after oil change?
  83. Help Hood Stuck closed, Hood latch cable seems loose
  84. Car Won't Turn On
  85. Help AC issue
  86. Help Stubborn misfire
  87. Help Persistent ODB Code P0447
  88. Help need help identifying new sounds
  89. Help 7at Transmission Fill Bolt Thread/Pitch?
  90. Help Weird knocking/popping noise?
  91. Help Recommendations for Synthetic Oil
  92. Valvoline 2 step fuel system treatment
  93. Help P0300 cylinders 1, 3, 5 equal misfires
  94. Any issues disconnecting battery? Audio other?
  95. Regular Gas
  96. Better oil for G37 with 130,000 miles
  97. Help tiny stream of fresh oil coming out tailpipes after oil change
  98. P0300, service engine light only flashes when moving
  99. Help No Crank, so No Start
  100. Help Towing G37X Question
