G37s Maintenance Cost
Looking at buying an Infiniti G37s (2011-2013) and wondering what the annual maintenance cost on this car would be? For the most part, seeing a lot of reviews saying this car is very reliable, low maintenance, and not very costly when it comes to maintenance/repairs.
Anyone have any record of how much they are averaging when it comes to maintenance/repairs?
Welcome to our little corner of the interwebs.
Two oil changes, two oil filters, maybe a set of tires if you spank it. Air filters every two or three years. Auto trans has "lifetime" fluid; changing it isn't exactly easy but can be done in your driveway. Most maintenance can be performed by Nissan dealers at less cost than Infiniti. Usually.
Be aware 2011 has a risk of a cam cover gasket failure that creates an internal leak that can ruin your engine if you don't understand the symptoms.
^^ i have an 11 g37sport AT- curious on that specific statement as well...can you elaborate please?, as the dealer mentioned that my valve cover gasket had a leak etc Are you talking about the rear timing cover gasket issue?
david g37
May 22, 2020 02:32 PM
RAVSPEC
Brakes/Suspension
Jun 21, 2018 01:10 PM
