Offset steering wheel
G37 2011 Coupe 25700 miles
I have two issues
offset steering wheel - fixed by wheel alignment twice but issue returns after 200 /300 miles
ESP and Slip Indactor lights come on after 3 or 4 miles - then BA light comes on - booked into dealer but six week waiting time ... ???
Any body have similar issues ..
best regards
Graham
I have two issues
best regards
Graham
Issue 1: if the allignment is going out of whack every 300 miles, you might have a worn or damaged tie rod end.
Issue 2: could be numerous things, but the first thing to try is adding a little fluid to the brake fluid reservoir. Sometimes it gets low as your breaks wear and the sensor trips as the fluid sloshes around. It will barely look low and you won't have to add much if this is the problem
Interesting thing about the offset steering wheel. Mine has been off for a few months. I got new tires last month and I told the alignment tech to make sure the wheel was centered, but in order to drive straight the wheel is cocked to the left. Why would the wheel be so tough to be on center?
