Help Ac pressure high
Old Aug 28, 2019 | 09:22 AM
Adbraxx's Avatar
Adbraxx
Ac pressure high
Hey guys I have replaced everything in my ac system except the condenser and expansion valve
Compressor doesn't kick. The freon it's good but pressure it's high it won't kick in IDK if system is clogged or what is the deal I spend soouch money and time in parts. Need all the help I can get!
Old Aug 28, 2019 | 09:28 AM
Baadnewsburr's Avatar
Baadnewsburr
When you say everything, can you list what you changed? did you test/change the pressure switch? if its bad the compressor wont turn on, check fuses/relays too
If the pressure is above spec you can remove some of it, overfilling can damage the compressor...
Old Aug 28, 2019 | 09:59 AM
Adbraxx's Avatar
Adbraxx
I replaced the compressor the low pressure switch I know the condenser it's new (there also was a leak of coolant who has been fixed) also changed thermostat (which apparently wasn't opening and also can cause high pressure) the AC only works when car it's cold Wich led me to think the thermostat and coolant have something to do with it since it stops once coolant gets warm
Old Aug 28, 2019 | 11:44 AM
Surfnazi's Avatar
Surfnazi
Did you check to see if you have too much freon? Take it to a garage that can evac. and refill with ac machine
Old Aug 28, 2019 | 12:15 PM
Adbraxx's Avatar
Adbraxx
Yeah the freon level it's correct.
Old Aug 28, 2019 | 12:32 PM
slartibartfast's Avatar
slartibartfast
I've been fighting this issue for over a year. Sometimes the compressor kicks on an blows cold so I'm pretty sure that's not the problem. The system has been evacuated and refill three times. I did replace the control unit in the console and that worked for two weeks but the problem returned. I'm pretty sure I have an electronics problem.
Old Aug 28, 2019 | 12:45 PM
Adbraxx's Avatar
Adbraxx
IDK man mine only works when cold. It's Soo annoying I really don't know what else to do I'm lost. But u should do self diagnosis for ipdm and see if it's actuating the compressor clutch and start from there
monty2003
General Tech Questions
Jul 18, 2024 12:06 PM
pricojorge
May 26, 2023 08:30 AM
Mrfudge
Jun 7, 2018 05:37 AM
Jimmy1
Jun 11, 2013 06:47 PM
DIE FAST
Mar 16, 2013 03:02 PM
