Decarbonizing Service
Old Jul 15, 2019 | 02:41 AM
TEAMMI's Avatar
TEAMMI
Any Infiniti Techs have feedback on decarbonizing service? Is it worth the cost for the routine service? Is it just a bottle of Seafoam?
Old Jul 15, 2019 | 05:18 AM
Surfnazi's Avatar
Surfnazi
Seafoam and let it sit as long as you can. 1 can of bg44k in gas and you're set
Old Jul 15, 2019 | 05:56 PM
Sig6MT's Avatar
Sig6MT
Can you Pls clarify what the decarbonizing service is intended to correct?
It sounds like carbon build up to me, and I suspect that it is something b/c carbon build-up normally impacts engines with direct injection. I understand that our G-37 have port injection, which is not prone to carbon build up.
Old Jul 15, 2019 | 11:31 PM
TEAMMI's Avatar
TEAMMI
It was a recommendation from Infiniti based on the cars time/mileage and known history. Pricey at 289.95 and a can of Seafoam can do same thing. Wanted to receive an actual Infiniti Technician opinion on the difference.
Old Jul 15, 2019 | 11:32 PM
TEAMMI's Avatar
TEAMMI
Infiniti also wants a fuel injection service at 289.95
Old Jul 16, 2019 | 12:22 AM
Atowsley's Avatar
Atowsley
Sounds scammy to me.
Old Jul 16, 2019 | 12:45 AM
Sig6MT's Avatar
Sig6MT
No clear that there is a problem, or what the dealer rep is trying to do
To keep fuel system and valves clean, I buy a case of Chevron Techron when on sale at Costco once a year. Then add a bottle every other tank full until I run out.
During that time, I use fuel with highest octane I can find and drive the car easy to avoid knocking.
Never had had any issues with any of our cars.
Old Jul 18, 2019 | 03:55 AM
Surfnazi's Avatar
Surfnazi
grubbs used to use bg machine that mixed 2 cans of cleaner into the fuel line and 1 can poured into tank, they stopped using it bc they had some issues with the fuel lines
Old Jul 24, 2019 | 03:04 AM
TEAMMI's Avatar
TEAMMI
Update: Took it to different Infiniti Dealership and they charge $289 for both de-carbonizing and fuel injection service. The kit includes 3 different cleaners. Two cleaners they just pour and let run through the throttle body and etc. The third cleaner they pour into engine but extract with a machine. Hope this info helps.
g37xdriver
19
Dec 5, 2016 11:14 PM
RealOne81
General Tech Questions
Jul 14, 2008 11:02 AM
