Fluid info
Old Apr 10, 2019 | 04:52 PM
Redgoyabean's Avatar
Redgoyabean
Fluid info
Hey guys, I'm doing some service on the G n need to clarify what type of fluid is needed, I'm doing my transfer case n both diffs, I've checked the FMS n while I'm probably close to finding the answers it's just taking to much time so if someone could plz tip your hat to a fellow n share some info. Thanks in advance.
Old Apr 10, 2019 | 05:48 PM
Selym's Avatar
Selym
This is from the 2013 sedan owner's manual:
Old Apr 10, 2019 | 06:37 PM
Redgoyabean
You sir are simply AMAZING, thank you so much.
Old Apr 10, 2019 | 08:08 PM
saywat?'s Avatar
saywat?
do u not have the owners manual?
Old Apr 10, 2019 | 09:08 PM
Redgoyabean
I believe so
Old Apr 11, 2019 | 01:32 AM
Said Amir's Avatar
Said Amir
I use Mobil one 75w-90 for diff and Valero atf for transfer case. Make sure the car is balanced on each end or you might have more or too little fluid. If anything if you have it jacked up pour fluid in it and then drop it down on a leveled surface and it will drain some out if not add some more.
Old Apr 11, 2019 | 09:08 AM
Redgoyabean
Thanks for the info
ryang37x
Sep 22, 2015 05:33 AM
ak1
General Tech Questions
Nov 22, 2013 03:36 PM
oldschool33
Jun 1, 2013 05:25 PM
tifosi
Apr 10, 2013 04:25 PM
8lackMacObs
13
Jan 10, 2012 03:38 PM
