Help Rear passenger window won't reset/relearn
Old Mar 21, 2019 | 02:15 PM
BluesG's Avatar
BluesG
I just recently bout a 09 g37x s sedan. I noticed the rear passenger window doesn't want to auto down or up. I tried the reset and relearn procedure about 10 times now. I even had to do all the windows after my car sit for about a month when I was replacing bushings and installing camber arms, toe bolts and rebuilding the cv joints. The battery died. No issues for the other 3 to relearn. The window goes up and down fine. It just doesn't want to relearn.
​​​​​​I've done a bit of searching and most issues get fixed with the reset/relearn.
Its not a huge issue, I'm just curious why that one window is being so stubborn.
Old Mar 21, 2019 | 03:16 PM
slartibartfast's Avatar
slartibartfast
I had this problem, dealer had to replace the window motor. Thankfully, mine crapped out while still under warranty.
Old Mar 21, 2019 | 08:16 PM
BluesG's Avatar
BluesG
I figured as much since searching didn't pull up anything else such as sensors. Oh well, I'll be on the look out for one for that just in case it goes out.
teahead
G37 Convertible
Feb 5, 2019 07:43 PM
rodrich
Jan 8, 2014 11:05 PM
Rikter
Jan 5, 2014 02:02 PM
xdarkgokux
Jul 2, 2013 12:42 PM
~Lefty~
May 9, 2013 08:31 AM
