True Level - getting car perfectly level for trans fluid measurments
Old Oct 14, 2019 | 01:36 PM
soundquest's Avatar
soundquest
Wondering where on the vehicle I can get the most accurate level for setting trans fluid at proper fill. Magnetic leveler affixed to underside of trans pan? leveler right on ledge in passenger doorjamb? What is the most accurate? Thanks.
Old Oct 14, 2019 | 06:13 PM
stealthee's Avatar
stealthee
You're probably never, ever going to find true level. Just get it to where it looks level with the eyeball and that is good enough. It is how any one else does it.
Old Oct 15, 2019 | 01:45 AM
slartibartfast's Avatar
slartibartfast
Don't overthink this. Just get it close and have at it.
Old Oct 15, 2019 | 09:15 AM
Poured cement floors are pretty level, IMO. The lower level in a ramp garage, for example. Also a pretty good location to measure floor-2-fender height when adjusting coil-overs.
Old Oct 15, 2019 | 10:17 AM
BULL's Avatar
BULL
Moderador
Leveled cement floor
Level to the flange of the trans/pan
Place car on 4 stands until the level reads leveled
That would be the best way
Old Oct 15, 2019 | 11:23 AM
Surfnazi's Avatar
Surfnazi
It doesnt have to be totally level
Old Oct 15, 2019 | 11:29 AM
BULL's Avatar
BULL
Moderador
At all, but it helps.
If you've ever taken the trans pan you'll see inside is a metal tube protruding with a flat end, any sort of angle can change everything.
I know that on the floor my car took 2 additional quarts in comparison to the floor.
Old Oct 15, 2019 | 02:06 PM
Surfnazi's Avatar
Surfnazi
You can use rhino ramps and a jack in the back
Old Oct 15, 2019 | 03:17 PM
soundquest's Avatar
soundquest
Thanks for the help. So just to clarify (and the job is done), I was asking where exactly to place the "level" (the actual tool, also called a leveler or torpedo level... the thing with the sight glasses with the yellow fluid and the bubble you line up in between the two lines) on the car to get the most accurate indication and guide of "true level" on the vehicle while have it on ramps in the front and being rased in the back with a jack (jack stands in the rear will not allow 100% true level unless you get lucky). I placed the level on the actual transmission pan (mine is magnetic so I just stuck it right on the pan to give me my readings. I got the bubble dead center right in the middle of the marks (which took some back and forth between the jack and the pan). The drain and fille (4 cycles) went flawlessly and the stream from the overflow hole at the last step of the procedure came out picture perfect with the pan temps at 100F (within FSM spec range) with my IR/laser thermometer. I used 16 quarts of the well-regarded honorable mention synthetic Valvoline MaxLife Dex/Merc. I expect my shifts will improve slightly (better timed, smoother transitions, etc) like has occurred in all of my vehicles when switching over to MaxLife trans. fluid. Not a horrible service to perform, but it does take time (and a well-rigged fluid injector setup -- my iteration was pretty fancy and worked extremly well... if I may toot my horn briefly).
Old Oct 16, 2019 | 01:34 PM
BULL's Avatar
BULL
Moderador
Give us some feed back in the future on this valvoline. I spend quite a bit of money on 12 quarts of nissan type f and feel like shifting should be better.
Old Oct 16, 2019 | 03:03 PM
Surfnazi's Avatar
Surfnazi
Nissan auto trans are picky better to stick with s-matic fluid
Old Oct 17, 2019 | 04:03 PM
BULL's Avatar
BULL
Moderador
Mts00p is what I bought which appears to be Matic S and not type f. Still feels like it could shift better
Old Oct 18, 2019 | 05:58 AM
Surfnazi's Avatar
Surfnazi
Depending on last drain fill you might have to do it again in like 20k miles since you only got like 5qts out and tc alone holds 2qts
Old Oct 27, 2019 | 02:55 PM
Victory's Avatar
Victory
Maxlife works fine in these transmissions. Had it in for over 20k mi now.
mcola
Oct 14, 2019 01:57 PM
UCLAG37
Jul 11, 2017 12:21 AM
hobbs
Oct 22, 2012 07:09 AM
jarena2104
Sep 11, 2010 12:32 PM
