PDA
View Full Version : Audio, Video & Electronics
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
  1. Looking for ideas, pictures or experiences for 1 15" sub enclosure
  2. Help No sound coming out of the speakers, swapped the amp, tested fuses, is it bcm?
  3. G37S Coupe Rhino Radio
  4. 2010 Base Coupe Audio
  5. Tesla style screen vs vline infotainment system
  6. Factory Bose Head Unit with Helix DSP: low inputs or high inputs??
  7. Help Resetting instrument cluster
  8. Help Gauge cluster lcd
  9. I only have audio on my driver side
  10. Help Help!!
  11. Dead Battery
  12. Help Speakers sizes and depth
  13. Help Accessory Signal in Trunk
  14. Upgrade 07-09 Non-Nav and Old Nav to: Newer 2010+ NAVIGATION Setup
  15. Help Battery drain after tsb update
  16. MPC Remote Starter
  17. Help Need relay trigger advice and location(s) please
  18. Help Factory Bose Head Unit with Helix .3 DSP
  19. Help My Screen doesn’t work
  20. Is Q50 and G37 BOSE amp direct swap and other intriguing questions
  21. sedan sub owners, whats your best way of getting the best noise/air in your trun
  22. Car immobilized and locksmith can't fix
  23. Help 2015 Q40 audio setup questions
  24. Dsp wiring
  25. Speedometer not working and lights on dash
  26. Help Naxa Nab 4003 wont connect to car
  27. Install aftermarket backup camera to Tesla style infotainment using OEM camera?
  28. Mystery Part
  29. How to get remote starter from previous owner to work?
  30. Help A 2012 G37x Coupe Bose audio adventure
  31. Ecu swap
  32. Whining sound from Bose
  33. Help Where to find washer pump harness?
  34. Help 2011 G37s Windows Stuck Down no power to door controls at all
  35. Help A few (hopefully small) electrical issues, need help
  36. Help Phoenix 13.6 harness issues
  37. Help No sound
  38. Question for Coupe Owners with Zenclosure
  39. Where my Dynaudio Coupe guys at? I have questions!
  40. Help Key Lock Problem
  41. Bluetooth TSBs
  42. Help Bluetooth TSBs
  43. Help 08 g37 6mt cant find back up camera control unit
  44. Help Identifying different NAV button trim
  45. Help non-nav to nav replacement 2011 g37x coupe
  46. Broken USB port, looking for replacement
  47. Took out BCM cables and used CRC wire dryer, but now it's worse?
  48. How do I remove this speed chime?
  49. Help 09 convertible Bose: tweeters, front mediums and central voice not working
  50. Non-nav touch screen conversion
  51. Help Where to mount fuse holder and how to open rings around main harness
  52. 2008 Sound System keeps cutting off (RCA cables maybe?)
  53. How to wire a subwoofer?
  54. Bluetooth
  55. Instrument Cluster Repaired / Red to white screen swap
  56. 2011 g37s: Issues with Bluetooth music streaming + phone calls
  57. Help High Frequency Noise
  58. XM antenna replacement
  59. URGENT - I messed up real bad!
  60. Help stock 6x9s?
  61. Help subwoofer hum
  62. Help 13.6'' tesla screen (phoenix) Sonar issue
  63. Apple Carplay on G37
  64. How to Add Bluetooth on Early Model G's without it
  65. Audio Streaming for Non Nav
  66. Programming Intelligent Key Without Specialized Tools
  67. New battery and now problem with the remote
  68. Help Aftermarket audio problems
  69. Help What does “shield” mean in FSM Harness Diagram?
  70. Help 37x with oil maintenance reset problem
  71. CD-Quality Audio through USB port?
  72. Brainiac In-Dash Tablet Screen
  73. G37 Non Bose factory deck amp hook up!
  74. Help G37 tesla screen no gauges
  75. Help Backup camera picture very cloudy
  76. New to my g37 rwd, help with aftermarket radio
  77. Help Software / Firmware update
  78. We need a better “how to” audio thread
  79. My 2011 Infiniti G37x Front Driver speaker blew
  80. 2012 G37 iphone doesn't skip song after 3 back to back skip
  81. Need help with the radio!
  82. Music from iPhone, 2008
  83. All windows and power locks do not work
  84. Boomerang and ScreenSlaver - PCBs to display a Raspberry Pi on the G37's Display
  85. Convert base model to Bose or go custom? (I like Bose)
  86. Won't play audio from iPhone
  87. Dead gauge cluster
  88. Help Bovee vs CoolStream Duo
  89. Help Installing Subwoofer Correct | Nonbose G37 Sedan
  90. Grounding kits
  91. Help Nav system wont turn off
  92. G37 Coupe Remote Start
  93. Help Got a quote on a sub install, any suggestions
  94. How I replaced / upgraded the center display with high-res Andriod Auto
  95. Help Key, TPMS, BRAKE, VDC, SLIP, CRUISE All On
  96. Need some help to UnFK my reverse cam. Wiring harness routing?
  97. Consult III from OBD2tool
  98. Newb here..looking for sub advice/recommendations
  99. Help Navigation system manual update way needed
  100. Help G37 dashboard screen updates
