PDA
View Full Version : Audio, Video & Electronics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
  1. Key problem or car ?
  2. Wipers not working
  3. Help Drivers side wiring diagram
  4. Keyless Entry Not Working in Cold Weather
  5. Navi Display blank, grey or with horizontal lines
  6. Help Swapping out the stock screen
  7. My AV Controller got replaced and I think it is OLD...
  8. Help Change picture on the Stock Screen
  9. Bose amp
  10. OEM Backup camera install question
  11. Got a custom sub box made!
  12. Help audio installer in the San Fernando Valley, CA area?
  13. Help display malfunction
  14. USB flashdrive VS Ipod
  15. Help! Control Unit is NOT working and so is Audio and Volume & Beeps
  16. Speaker/Sub Depths?
  17. 2012 G37 convertible I Phone 6 and Bluetooth
  18. Info Needed: '09 G37x Rear door speakers full range?
  19. SirriusXM NAVTraffic availability
  20. My thoughts on Drivers Sound Stage
  21. everything going heywire, all lights on!!
  22. How can I play music from my phone in the car?
  23. Sub Enclosure Options
  24. help with door and dash speaker
  25. Stereo problems
  26. Help Adding Nav 2011 Vert
  27. Help Terrifying sound quality
  28. Dead car, even after battery change. HELP?!
  29. Bad instrument LED's
  30. Laser Jammer install question
  31. Update NAV map?
  32. Back-up warning indicator stays on, nothing in the way, though
  33. Key fob & windows
  34. Turn signal module?
  35. Help Odd display issue
  36. Help Steering Wheel Shortcut for Changing Songs on iPod?
  37. 2010 G37 Nav Video Input?
  38. 2011 G37x Sedan Sound Deadening
  39. Reverse lights wont work!
  40. Nav Help
  41. Using iPhone for music searching by artist
  42. Has anyone wired the factory camera into the A/V input?
  43. DVD Playback?
  44. iPod connector no longer works on 2009 G37....
  45. 09 Navi package Audio?
  46. Anyone know the brake switch wire colors.
  47. ecu diagram?
  48. Picking up 2012 G37 coupe
  49. TouchScreen
  50. 08 coupe compact flash
  51. What is Inverter VCC?
  52. Help Help with Navi system.
  53. Some Questions About Remote Start.
  54. Help Battery Drain Issue
  55. 2009 Non Bose stereo harness breakdown please
  56. Interior Speakers Swap
  57. Aftermarket Carplay Options
  58. Bluetooth Low In-Call Volume
  59. No sound
  60. Sound Ordnance B-8PTD
  61. OEM Style Rocker Switch?
  62. Help Nav System updates
  63. Another Sub and Amp Install
  64. Need help choosing custom trunk solution, Maximum bass
  65. Focal DSA 500 RT
  66. Help Head Unit does not remember setttings, CD place
  67. New G37 Owner/Audio Question
  68. USB to bluetooth audio adapter
  69. Help RCA input broken
  70. Homelink
  71. Tweeter Install?
  72. How do I download the address book in my Galaxy4?
  73. Bluetooth voice commands and Moto 360 smart watch
  74. Help 2012 G37x cheapest way to get video from iPhone 4?
  75. navigation update
  76. Help Dashcam Hardwiring: Which fuse?
  77. android in car...
  78. upgrading audio
  79. Streaming in G37 with no navi
  80. Can you update the mutlimedia screen?
  81. How to: replace your center channel speaker.
  82. Heads up- 2015 Navigation update keys are not working.
  83. podcast playback problems with iPhone 5 and 2013 G
  84. Iphone 6 Compatibility with 2010 g37x
  85. help have to buy new cluster
  86. 11 coupe no longer has rca hookup ;(
  87. Help USB - always starts from 1st song on memory card
  88. Help Adding switch to Backup Camera?
  89. Help running AUX video RCA cable into center console
  90. how to replace the analog clock light?
  91. Which Signal Line for DQ-61?
  92. G37 Coupe Mounting Amp to Seatback / Trunk
  93. Help Streaming Spotify on 2012 g37X w/ Nav via Andriod
  94. DEI Xpresskit RSR Remote Start
  95. Tweeter speaker stained
  96. Bluetooth phone question
  97. Amp Recommendation
  98. Adding an amp to the stock speakers
  99. Thinking about upgrading to an aftermarket radio head unit, need some help
  100. Is there an aux in the g37?
