Help Key Lock Problem
Old Dec 2, 2020 | 09:27 PM
hudzpud's Avatar
hudzpud
Question Key Lock Problem
My car is a 2013 infiniti g37, last saturday I used my 2nd key fob (programmed by a 3rd company, I had no problems until this problem occurred) to drive and occasionally the dash icon with a red car with a key symbol inside of it would flash when I drove. Had no problems until I drove today when using either key fob would not turn on the car via push to start and the buttons on the door handle would not lock/unlock the car when the fob is near it. The only way to turn on the car was to stick the key fob inside the slot above the OBD port. The buttons on the fob work, I changed the battery on both fobs = still same issue. Wondering if anyone has experienced this problem and got any clue to solving it. Thanks!
Old Dec 2, 2020 | 09:30 PM
hudzpud's Avatar
hudzpud
Also now the car with key dash icon pops up 24/7, before this problemed occurred I have not seen it on my dash this consistent like it is now.
Old Dec 3, 2020 | 12:04 AM
hiddensalami's Avatar
hiddensalami
No way. I’ve been having the exact same problem. I just got my keys programmed at Batteries Plus Bulbs and it worked great for a few weeks until recently it’s been not detecting the key. It happens maybe half the time I try to use it, seems like it takes the car a few seconds to wake up and sense the key. Anyone have a solution?
Old Dec 3, 2020 | 11:45 AM
hudzpud's Avatar
hudzpud
Have you tried contacting Batteries Plus Bulbs to see if they can maybe help you with that issue. My 2nd programmed fob was made 2 years ago, so I forgot the company that did it for me.
Old Dec 3, 2020 | 12:07 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Odd for a fob/bcm to lose its programming. You sure the batteries used are good & fresh? Any issues with the first fob? Assuming no issues, try swapping batteries from first to 2nd fob?
Old Dec 3, 2020 | 02:15 PM
hudzpud's Avatar
hudzpud
I believe the batteries should be good, I bough them new from walmart months ago. I just changed the the batteries for both again (tried on car= still same issue) then switched (still same issue). Should I contact a infinti dealer or maybe go to a 3rd party programmer?
Old Dec 6, 2020 | 11:04 AM
hiddensalami
I did change the batteries with ones from target that were energizer brand. They, for some reason, we’re not working properly. I went on Amazon and bought the AmazonBasics CR2032 5 pack battery and haven’t had the problem since. I’m not sure if the Energizer batteries were defective, but when I put them in, I was still getting the battery warning when I first started the Car. Try changing the batteries with Amazon ones.
Old Dec 6, 2020 | 02:39 PM
ILM-NC G37S's Avatar
ILM-NC G37S
If I had a dollar for every brand new pack of "name brand" CR2032 batteries (hell, coin batteries in general) that were "dead on arrival" I'd be a millionaire.
Not saying this is directly related to the main issue, but more often than not those fob batteries are to blame.
Burnyburn52
Feb 28, 2020 06:41 PM
Pnellyg37x
May 1, 2018 05:32 PM
Poe408
Aug 3, 2010 03:05 PM
cullan
Oct 20, 2008 05:55 PM
