PDA
View Full Version : G37 Sedan
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. Door button replacement
  2. Should I get wheel spacers?
  3. AC Fresh Air and Recirculation Mode Randomly Switches
  4. My G37 keeps getting lower
  5. Windshield washer liquid fill cap
  6. cut wire
  7. Cold start RPM drops for a second
  8. Hummin and Howlin from front end
  9. ONEighty NYC is still at it (sedan brake caliper project)
  10. 6mt new parking brake issues
  11. Everlasting Coolant Leak
  12. Car seems to Hiccup at idle and low RPM
  13. Bluetooth not connecting
  14. My 2009 g37 journey vibrates
  15. Anyone know the proper way to clean Blitz sus air filters?
  16. Does she sound good?
  17. Power cutting at 3-4K
  18. Suspension Issues @ 105k - Keep or trade in?
  19. BCM issue
  20. What is this clip?
  21. Bumper bolts not fully threading
  22. Black B-Pillar Exterior Trim
  23. Should I change my transmission fluid?
  24. Introducing: Swamp Car - 2013 G37xS
  25. 2011 G37x Sedan – Cylinder Misfire Issues (P0301, Now P0301 & P0303)
  26. Blinkers not working
  27. Carbon bumper with carbon grille
  28. What is this thing for?
  29. Weird high pitched noise
  30. Noise coming from dash area after start up
  31. Rear Diff Decision
  32. 2010 G37 Sedan: Headlight Troubleshooting Help
  33. K6030-1NF7A For Sale
  34. 2009 G37XS Sedan Rear Differential swap Question
  35. P2096 after Kinetix HFC install
  36. How to adjust headlights, and how do I replace this seal?
  37. No headliner lights turning on?
  38. New swaybar endlinks really bring the car back to life
  39. What is the safest Ecu Tune to do to my g37?
  40. Emblem removal aftermath
  41. Stuttering at Idle, Drive, Park, etc.
  42. Hissing noise in my exhaust
  43. 2009 Infiniti G37X Engine Ticking and Slight Rpm spike at Idle
  44. G37 Lower Grill
  45. 2012 G37x sedan transmission problem
  46. Low power steering fluid and leaking on top of alternator
  47. Do the G37 fuel rail dampers go bad?
  48. 2012 G37 catalytic converter rattle. Are these cheap ones on ebay any good?
  49. My car won't turn off after trying to reprogram a spare Key
  50. 09 Infiniti G37 Sedan
  51. Overheating / Temperature gauge is bouncing around and redlining
  52. G37 sluggish after installing aam competition resonated hfc + aam y pipe
  53. Issue With Gauge Cluster Gauges
  54. Carbon fiber rain guards
  55. Battery/Brake light Flashing on and off
  56. Code P0301 - Head Gasket Failure?
  57. G25 floor mats in G37S
  58. 2009 G37 Camera
  59. Gauge cluster & backup camera not working
  60. Check engine light on > p010b > replaced MAF sensor -> car goes into limp mode
  61. Mysterious front end noise
  62. Need help with suspension
  63. milky oil, coolant leaking down rear driver side of engine
  64. Coolant on ground and smoke coming from under driver side off the windshield
  65. Certified pre-owned G37 from Infiniti
  66. Dash Completely Dark
  67. Need the boys for this one!
  68. Do I need adjustable camber arms? Toe bolts?
  69. 2011 g37xs sedan u1000 has power but no crank no start
  70. Write Up: Swapping 07-08 G35 Leather onto a 09-12 G37 door panel
  71. 2009-2010 g37xS sedan headlight compatability
  72. Misfire after Battery removal
  73. Sunroof won't close or open
  74. Help! G37 or is it a g37s ?
  75. Intelligent key not working after dash replacement
  76. Mid pipe that fit g37x sedan 2011
  77. G37 repair parts #
  78. Any ideas on this radio/LCD issue?
  79. Coolant Pressure
  80. Dipstick Hitting Something / Hard to Read
  81. 2013 G37X Sedan Catalytic Converter Issue
  82. Need Help finding this part
  83. Transmission fluid change
  84. Struts / Shocks
  85. G37 Sedan Rear License Plate Bracket Repair
  86. Z1 touring sedan exhaust
  87. 2010 G37 Roof Seam Water Leak
  88. Headlight Troubleshooting on Inifiniti g37 sedan 2010
  89. Axle Break
  90. Occasional Engine Rattle During Startup
  91. How much would this repair cost?
  92. PHILIPS Ultinon LED bulbs (for in & out) Did you use a LED Adapter CANbus?
  93. Car won’t start after changed blown battery fuse
  94. 2011 G37 Keyfob Issues
  95. 2011 G37xS Sedan u1000 has power but no crank no start
  96. Engine swap
  97. Electrical issue IPDM
  98. Any DIY to install Autostarter to 2010 G37X
  99. Car won't start
  100. 2009 g37 no sound from radio untill you drive for a while
