Axle Break
Old Dec 18, 2024 | 09:46 AM
vqdunk's Avatar
vqdunk
Axle Break
Sorry I’m new to the forums,
but my axle just tore, and doing research I found out it’s going to be a consistent problem with a lowered g. I heard about the “3/13” axles that are longer and in theory should work, but has anyone tried that? I’ve also talked to some guys and they said it’s a consistent problem for AWD lowered g’s so if I pull the fuse to make it rwd and put rwd focused suspension will the axle break stop? (Pictures of leak and car below)
Old Dec 20, 2024 | 07:09 PM
beefychicken's Avatar
beefychicken
The picture you shared is the boot for the steering rack. It is leaking, assuming the car is high mileage, you could just keep an eye on the power steering fluid level until you are able to replace the rack.
Just my take based on the pic.
As for the AWD and lowering, my AWD coupe has been lowered about 1 1/2 inches (38mm) for about 30,000 miles (48,000km) and i have had no issues with the axle boots.
Old Dec 20, 2024 | 09:28 PM
socketz67's Avatar
socketz67
Community Builder
I haven't seen many complaints about broken axles due to lowering, AWD or RWD. Where did you read that this is a consistent problem?
Most of the users here are lowered.
Old Dec 26, 2024 | 01:02 PM
digital.aaron's Avatar
digital.aaron
I didn't "break" an axle, but I did rip a boot significantly while swapping out front suspension parts on a slammed xS. It was my fault for not better supporting the hanging axle. And maybe the slight forced repositioning of the axle to get some of the parts in and out didn't help either. I drove with a torn boot and leaky axle for over a year. I eventually could feel the resistance at low speeds of the unproperly lubed axle, so I had both fronts replaced with genuine infiniti axles with warranty.
Maz.VQ
Jul 22, 2024 01:40 PM
ChinkyChoy
41
Jul 8, 2023 11:13 AM
Deelow
Oct 30, 2022 11:09 PM
