Headlight Troubleshooting on Inifiniti g37 sedan 2010
Old Dec 20, 2024 | 12:28 AM
Turro's Avatar
Turro
My left side headlight went out. It flickered and then went out. I figured it was just my light bulb that went out so i replaced it and still didn't work. I checked my headlight fuse and it looked good, then i replaced my ballast and igniting cable and still didn't work. I thought it was the wire that connects to the ballast bust i checked it with my meter and it was giving out 12v 11.8v to be exact. Any idea of what it is?
Old Dec 20, 2024 | 10:46 AM
13_SkylineSedan's Avatar
13_SkylineSedan
Here's the FSM for your car's exterior lights:
https://www.nicoclub.com/service-man...2010%2FEXL.pdf
Scroll down below that viewing window and you can "click here to download a copy". That can help you understand the system.
If you're getting +12 volts at the ballast connector make sure the ground pin is reading continuity to the chassis. And if that's also solid then the fault can ONLY be the ballast or bulb. Did you use OEM parts? You could also try swapping the bulb and/or ballast from the passenger side as a test. Let us know what you find.
MrRedSport
Nov 15, 2021 11:24 AM
Dkonez
Oct 26, 2019 07:11 PM
jdavila35
Mar 27, 2016 03:08 PM
NeverBoneStock
Nov 13, 2015 01:01 PM
Bax1864
Nov 3, 2015 02:56 AM
