- I need help with wheels
- Window rubber moulding
- Steering Lock Not Unlocking - Does it happen on the newer G37s?
- 100k mi tune up
- Bc Coilovers
- G37x Sedan on Eibach Lowering Springs. Do you suggest 19s or 20s?
- New Member Just Bought a 2013 G37S Compared to Maxima
- What's the worse/best color for a Sedan?
- Sudden acceleration
- Does your oil has a smell of gas?
- What actually is leaking?
- Best axle back with no drone/excessive loudness
- Picture of rear of sedan
- Berk Resonated Test Pipe
- Cracked Dash, Fogged Headlights 2010 G37
- Coolant leak near passenger front tire
- P2098
- No Power, Converter?
- Another wheel fitment question
- Thinking of getting new wheels
- HELP installing 4 channel amp
- G37x engine
- 2009 G37x Slipping 4th to 5th gear
- droopy tips
- '11 AWD sedan front end vibration
- O2 sensor problem
- Catalytic converter clogged?
- Lost Power after spark plugs change
- Lost power after changing spark plugs
- Best Aftermarket Rack and Pinion Assy
- engine vin number
- Auto/Rain sense wipers
- Overtightened throttle body
- Anyone selling a Topspeed Sedan straight Axleback?
- Buying new wheels
- Dealership can't solve coolant leak - Need advice
- Custom Motordyne
- Advice needed - DIY Wrap on a sedan sport
- Custom Exhaust Sound
- G37x Wheels and Offset
- Q60 Speedometer on a g37
- Loose gas pedal?
- 13X Sedan Rear Timing Gasket leak has finally showed itself
- Blinkers don’t work after car wash
- Accessory loss after battery change
- 275 tyre in front?
- Anyone selling a z1 intake?
- Throttle Controller
- Broken doors
- Replacement Tail Light For Sale (Right Rear tail light only) Brand New
- Question about engine swapping
- 2013 G37x sedan suspension upgrade
- She's BACK!
- HELP! Limp mode?
- 09 g37 sedan staggered 20 inch wheel alignment
- Advice for suspension on AE Sedan
- Aftermarket stainless Y-pipe for X sedan
- Low-key catback for the X sedan
- WTB stock g37 sedan catalytic converters
- Need your advice
- Abnormal start up, also another issue
- Passenger seat wont move forward (sometimes)
- Dash lights lit up and Speedometer not working
- G35 seats in G37
- Abnormal Startup
- Noise at startup
- Replacing Tensioner
- Questions about installing coilovers
- Sport bumper and distance sensor sedan
- Mishimoto G37 Catch Can Thoughts
- Do I need camber arms for bc racing coilovers?
- 2013 G37x sedan non-sport to sport conversion
- Problem with gear
- Throttle body swap Question
- Vibration & bad acceleration
- Help - engine knock problem
- Lowering my G37 Sport (Sedan) on Swift and Tein EnduraPro Plus
- Resonator recommendations
- Which test pipes?
- Another radiator hose leak after repair
- Suspension shot - looking to upgrade
- Rear Suspension - What part is this?
- Nismo 370z rear sway in g37x grinding issue
- Sedan Journey front lip... does it fit the SPORT bumper?
- Forged wheel Look
- Tire SIZE help on 19 Rays on non sports RWD sedan
- My G37 won’t start
- 2009 g37 Sedan aftermarket headlights
- Any one running underdrive light weight crank pulley kits?
- Anybody know what this plastic tray is?
- 370Z exhaust on my G37
- Do people still have acceleration lag issues?
- Installed a new battery
- 13 G37 Questions - sluggish acceleration
- instrument cluster insane rattle noise
- 2012 Infiniti G37 sedan overheating
- Interior wood trim
- I bought a Crashed & Dirty Auction Car...2010 G37 w/ 6MT
- Quickjack Cautionary Tale
- Hazard lights and wipers won’t turn off
