- Low idle 500rpm or lower after throttle body cleaning fixed!
- Cowl Top Cover (RH)
- DTC's Galore Help needed from across the Pond
- broken PIDs
- FI cats + Megan mid pipe = resonance from hell
- 3 belts shredded after alternator change G37XS (PLEASE HELP)
- How do I pass inspection with a full exhaust?
- 2009 G37 sedan grille
- Q40 - Exhaust Setup Question
- 2011 G37 Sounds like a helicopter
- I lowered my car and this sound appeared
- Are the rear LCA bushings liquid filled?
- Slightly red oil?
- Road trip considerations
- coolant leak
- Stillen exhaust issue, need help for muffler options
- Does anyone know what this goes to?
- In need of a bumper (2009 moonlight white)
- 2.75 in intakes
- What is the purpose of this?
- 7at help
- Bumper Question
- My 2009 G37x burps and bumps when idling
- 200k Miles
- G37 Instrument Cluster
- Aftermarket catback with stock Cats - How much power?
- What times are 3.7s running with bolt-ons and NO TUNE
- 2013 G37xS - Interior lights just stopped working
- Problems at start up
- Steering rack leak
- Code P2098 & P0300
- 09 G37x steering
- Floor Mats for 2008 G37S
- Rev speed won’t pass 4000
- Import g37
- G37 shifting by itself in manual mode
- 2013 Infinity G37 Sedan - Bumper/Fender Gap Above Headlight
- Slip light turns on between 4 and 5k rpms in every gear
- P2a00 p2a03
- Where are working FSMs?
- Nitpicky? After accident front end rebuilt
- Q40 - Sport Bumper Conversion
- Questions about built transmissions and built differential
- Scraping sway bar
- G37 coupe exhaust on sedan
- 19" Wheels Rubbing
- B-Pillar replacement parts or repair
- G35x Exhaust on G37x
- interior heat insulation?
- Lower subframe brake replacement part-front
- bands for just a tune?
- Accent on black car
- Obsessing with keeping the car perfect?
- Negative Camber issue
- 06-07 WRX CS2 Front Lip on 2010 G37x Non-S front bumper
- Transmission leak quote thoughts?
- G37x Sedan won’t start
- Thinking about getting new coilovers
- Too much oil?
- Question about OEM Rear deck spoiler
- 2009 Sport / MT Spark Plugs
- FI Exhaust: 2-1/4" vs 2-1/2"
- Loss Of Throttle Response/Torque/Power
- Question about dynocom
- Transmission delayed when shifting into drive?
- Overdue post , Goodbye G35x
- Side Mirror Compatibility
- Transmission swap
- Help! Power loss after pumping 87 octane
- Weird Rattle sound on cold start (G37X 2012)
- Need help 2010 g37 sedan cranks but no start
- What is the part called that hangs the exhaust in the back?
- Can someone please tell me what this part is?
- Passenger side cooling fan not working
- Clunk Noise
- What part is this for the rear seat?
- Saving destinations in navigation system
- How to make fast intentions exhaust louder
- G37 Oil Filter
- Instrument cluster lighting
- CV axle issue
- Q50 wheels on g37
- Fog Lamp Assembly
- Help - Key light & No Cruise Control
- Need replacement Y-Pipe
- ISO new struts
- Coilovers settling or something else
- Z1 subframe collars won’t go in
- G37x Stalls At Startup
- 2013 2wd Sedan 7at vs 2013 2wd coupe 7at. Interchangable?
- Another HFC thread with exhaust questions
- p0420 HFC or Stock cats for fix
- Dead steering wheel up/down adjustment
- Anyone running these wheels?
- Lowering
- Help car down key fob
- Misfire cylinder #2 mechanic stumped
- What hardware/ bolts do I need to install test pipes?
- G37xS Custom Exhaust Setup (SCS Catback). Resonated or not resonated?
- Transmission TCM
