PDA
View Full Version : G37 Sedan
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. Fuel Gauge & Map Sensor
  2. Over filled engine oil
  3. Will it Fit 275/40/17 on stock rims?
  4. Floor mat retention post
  5. Limp mode problems
  6. Is driveshaft coupling same on 2008 G37 Sedan / Coupe ?
  7. G37s With Black Seats BUT White dash?
  8. Are Vqcarboncustoms intakes a good and cheeper alternative to stillen or z1?
  9. 2.25" resonator delete vs 2.5" fabricated resonator delete?
  10. Anyone selling gthaus mid pipe for g37 sedan?
  11. Anyone selling top speed pro-1 y back for g37 sedan?
  12. g37 plastic rattle EVERYWHERE
  13. SPORT Bumper finally!
  14. Metal grinding feeling in gas pedal when accelerating
  15. Cold start engine knock after replacing a Variable Timing Solenoid
  16. Midpipes for 2012 G37 Sedan
  17. Wheel bearing or other?
  18. 2012 G37xS Bouncy Ride. Swift Springs and 20inch wheels
  19. Coupe tailpipes vs Sedan tailpipes
  20. 2009 Sedan bumper difference Sport vs. Non-Sport
  21. custom resonator delete vs gthaus mid pipe
  22. Help cancel seat synchronization
  23. Any @G” drivers in Northern Virginia
  24. Had my g37 for a month someone rear ends me
  25. How much would it cost to fix?
  26. Window Trim Color
  27. Help with rear window chrome trim part number
  28. question for people with coilovers + 18" wheels
  29. Stock tow hook mount or modded? New to me 2013 G37 Sedan
  30. Found the rattle finally
  31. What tires fit?
  32. Dumb question...does the G37 have shocks?
  33. Extended Warranty runs out November for G37xS, 34k miles. What to inspect?
  34. 2011 Sedan Caliper Colors
  35. Motordyne exhaust rubbing against hotchkis sways
  36. 2013 Infiniti G37xS Sedan Service
  37. Cold Air Intakes
  38. 2011 Sedan Brake Issues
  39. P03000/P0301 Issues on 2010 G37
  40. Can g37x run staggered rims?
  41. Which 19"s? opinion on black or stock w/pics
  42. Raspy noise at start up
  43. Clutch pedal going soft after hard driving, please help!
  44. 2013 G37 XS overheating
  45. Lowering Springs Question
  46. High-Flow Cats
  47. Oil change...BRAND
  48. Closest thing to Motordyne ART Pipes
  49. Quality shocks for a G37x sedan?
  50. Rear Flap Loose
  51. Q50 Oil Cooler on a G37
  52. Question about Limp Mode
  53. High flow cats - G37 Sedan
  54. 2010 G37x P0462 error code fuel level sensor
  55. New guy37x
  56. Ark Exhaust Resonator
  57. Question about an intake system
  58. Wiring Harness Clips
  59. GRRR - Power Washed off the Paint
  60. So long, G37! Its been a good run (parting out current mods + next car!)
  61. HELP! Catalytic converter bolts going to the X pipe on exhaust
  62. Nav Questions
  63. Stock Y pipe length?
  64. Loss of power
  65. Looking for ideas to mod my sedan
  66. What to look for in a 2010 G37S 6mt
  67. Ipod connectivity on 2009 G37x
  68. Broken sensor behind oil filter with no check engine light
  69. Nismo / IPL H-pipe on Sedan
  70. Engine cover removal for better heat dissipation
  71. Recommended TPMS
  72. G37S Clutch Replacement
  73. Installed paddle shifters on my non s model
  74. Passenger Side Leak
  75. Best sun shade for 2011 G37
  76. Cracks in my G37 dashboard - Need advice
  77. 18x8 square setup best offset for stock height Help!
  78. 2011 G37 Sedan Sport Front Lip
  79. Rims
  80. Need purchase Advice - G37s 6MT 2013
  81. Need new mechanic in New England
  82. Power Gains On Exhaust Install
  83. 18' VS 19' Wheel Bend?
  84. Can a door that came off a 2010 Infiniti G37x sedán fit a 2009 g37?
  85. Passenger Side Mirror Cover
  86. Exhaust
  87. Exhaust Problems
  88. Just did a transmission fluid change at 200,000 km (~120k miles)
  89. 2010 Sedan resto-mod
  90. Ash Tray question
  91. G37x 7 AT - Overheating at the track
  92. deck of cards in bicycle wheel noise
  93. Help - What is this hose called?
  94. my fat tires
  95. Door hinges
  96. Help with Oxygen Sensor Wiring
  97. G37x Sedan 17 inch wheel project
  98. Insurance denied my claim?
  99. G37 bolster pinching nerve in my leg
  100. 2010 X Springs and mods and wheels
