- 1320 Performance Vs Berk technology
- Need help diagnosing an issue after rain
- Parasitic battery drain
- Question about center bore
- 4300k vs 5000k
- Pinpointing Noise Source - Driver's Side Wheel
- Passenger side floor leaks
- Engine Air Intake Hose Replacement Questions
- Shorties + Test Pipes or Long Tube Headers
- 2009 g37x hood cable
- Help G37 with idle issues
- Infiniti's in Japan
- Looking for Catback
- U0101
- anyone know this part number?
- Horn has loss of ground in steering wheel (long) MY2009 G37x sedan
- Top speed axel back sound difference with resonated test pipes
- Top Speed vs Megan Racing Y-Back Exhaust?
- Horn Sound Issue
- Coolant
- Battery problem. Need some assistance please
- idle issue only in park or Drive
- Engine Swap
- Strange Steering issue 2013 G37x
- G37 won’t turn over but has power
- Exhaust advice for stock G37
- Coolant Fluid
- Power steering fluid
- Strange clicking noise
- P2A00 failed smog after multiple shops (unlikely cat)
- Power Steering
- Electrical problem
- Please help locate source of coolant leak - vid attached
- Engine swap
- Model year compatability
- Many odd problems with G37X
- Question about the isr y pipe
- Brakenetic GT Rotors Review
- Wiring anniversary seats into my g35 08 sedan
- 2010 G37x Intelligent Cruise Sensor
- Burning oil smell
- Red key light
- Shift to park message while car is off & in park already. Constant beep
- 09 g37x, no crank, all lights and codes
- Need Help Diagnosing Electrical Issues (BCM/CAN Bus Related)
- Tuned G37 Sedan 7AT 0-60
- slip, VDC off and airbag lights on
- 2011 G37 Sedan P0075 Code - Intake Valve Control Circuit (Bank 1)
- Rear Camera Wiring Issue
- 2009 G37X Sedan - Just bought - Advice on service?
- G37 Sedan Decklid Spoiler
- OEM Headlight swap to Aftermarket
- HELP: P0106 "MAP Sensor", P0302 “Cylinder 2 Misfire", Engine sounds like death
- Replacing F/R crossmembers - recommendations
- g37 headlight housing
- Isr y pipe + kinetix hfc with stock exhaust?
- P0300/2 Code on 2009 Infiniti G37X
- Floor mat hooks and grommets
- Battery upgrade fail
- Help valve body
- Car won’t start at times
- Anyone running aam competition rhfc with stock exhaust on their G37?
- Code p0420 and hearing a rattle when accelerate also think power steering whine
- No ignition - Help
- G37 Sedan Passenger Mirror Help
- Bose systems
- Oem or Berks hfc?
- Car shuts off when I clip on 02 sensor
- Help identifying brake calipers
- Ok new here and I really hope there are active members.
- G37 Evaporator Cleaning Guide (Klima Cleaner Pro)
- Can I replace just ball joints?
- 2012 G37 Sedan advice
- Best Aftermarket Cats? Trying to minimize drone
- ECU Nats Delete
- Car is stuck in limp mode
- Alignment is off
- Bearings Repair
- Excellent leather cleaner (3D LVP)
- Control Arm
- Radio Issues
- 2011 G37 Sedan 3D Model
- 2011 G37 stuttering and backfiring
- 2013 G37 LIMP MODE Help
- Sedan, Rear Sunroof Drains
- 2012 G37 Sedan Key Fob Issue
- Inherited G37 226k
- Insurance says the car is fixable... what do you guys think?
- PO106 Can't be fixed
- What exactly is leaking?
- Qx50 to g37x engine swap
- 2012 G37 - Door Button/Push Start does not work
- New owner looking for guidance
- Will an ipod Touch 6th Gen play music on 2012 G37x?
- Nismo Wheels on X Sedan
- Advice on Purchase
- Son just got G37x and I have one burning question
- Mixing All Season with Summer Tires
- Need opinion on this coolant leak
- Clunking noise
