PDA
View Full Version : G37 Sedan
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. Possible Cooling System Issue
  2. Resonator needed
  3. nissan rogue paddle shifters on G37
  4. You're enjoying the good old days now
  5. Selling Advice
  6. Sunroof question
  7. Front Strut Assembly help
  8. OEM Airbox Clips
  9. 2009 to 2010 Front end AFS question
  10. Help… Radio am/fm not coming on
  11. Which fuses disable the car?
  12. best suspension for g37x sedan
  13. G37x driver side squeak when turning going over bumps
  14. Front awd suspension help
  15. Fixable bent rim?
  16. Best Bang for Buck parts
  17. Rough idle and P0603
  18. anyone have the metal undershroud by z1 or another brand
  19. Gas or exhaust smell coming into the cabin
  20. G37x electrical shift issue
  21. Grab handle questions
  22. So its been a while since my last mod... lay it on me!
  23. 7AT woes and ITB10-075
  24. Wiring Harness Question
  25. Changed Spark plugs and coils, now it won't start
  26. EFlexFuel - Change my mind - Help!
  27. Spacer thickness for stock 17in wheels to get flush fitment?
  28. Rims and Tires
  29. Oil pressure light
  30. Top Speed Pro 1 muffler delete pipes
  31. The two rear subframe nuts keep coming loose
  32. Electrical Plugs behind Bumper
  33. 09 G37 Cluster issue
  34. Are AFE dry filters worth it?
  35. HELP! p1092 p0300
  36. Top mounted hanging pedal conversion
  37. Complex Question about AV Radio Control Modules
  38. Blew my first hose
  39. Front axle thread stripped, ideas?
  40. Replica Akebono Caliper Dangers
  41. What’s the first thing I should do to my stock g37x?
  42. OEM Infiniti Enkei 18x7.5 SQ Wheels Clear Akenono BBK
  43. 19 inch coupe wheels on g37xs sedan awd
  44. Groaning/rumbling sound when turning right
  45. Possible Fan issue
  46. what size wheel spacers for stock height
  47. Incorrect Control AV Radio Box
  48. 2013 malbec black sedan 6mt
  49. 2011 Infiniti G37x driver's power seat + passenger windows issue
  50. non US company making G37 fender flares
  51. 2010 G37x S daytime running lights
  52. G37 bogging down
  53. Engine swap
  54. Coolant scent inside cab no visible leak
  55. I was a fun ride.
  56. Neverending TPMS Saga
  57. G37s OEM Spoiler
  58. My G37 Smoke Leak
  59. My car was declared a total loss
  60. 2013 G37x backlight on climate control, radio, navigation, and gear select not w
  61. Catalytic Converters Help
  62. Anyone know the name of this Engine Bay Cap?
  63. Buying a used G37
  64. Electrical Issues and Limp Mode
  65. Sea of codes on 2013 Infiniti g37x
  66. It's been a good run
  67. 2012 g37xs power steering fluid low
  68. Device to see all engine stats live
  69. Electronic Steering Column Lock (ESCL) - Junk car needed
  70. 2011 Automatic, No Reverse Signal
  71. G37 Misfire in Cylinder 3 (p0303) + Multiple misfire (P0300) What should I do?
  72. 2010 Infiniti g37x not starting
  73. AutoKits X still in Business?
  74. Bcm getting wet
  75. Are there aftermarket radiator support covers out there?
  76. Front differential noise - HELP!
  77. 2013 g37x navigation, radio, clock, and climate control backlight not working
  78. Horrible shaking when braking after high speeds
  79. Hard engine rattle and misfires
  80. Electronic steering column lock
  81. new Y pipe and Cats (2012 sedan)
  82. Cylinder 3 Misfire/loss of compression
  83. New Y pipe and cats (2012 g37xs sedan)
  84. Will the ISR Y-Pipe fit my AWD Sedan?
  85. Issues with starting.. brake pedal sensor?
  86. VDC Error light on, limp mode engaged, transmission locked
  87. 2013 g37x navigation, radio, clock, and climate control backlight not working.
  88. Blacked out factory style projector headlights
  89. Best car ever
  90. Full Air Lift 3P kit ( Located in South Florida )
  91. Are G37 sedan fenders interchangeable on different years?
  92. intermittent loss of acceleration (power)
  93. Atlanta car clubs
  94. Door slam-no key
  95. Strange Crank No Start Issue
  96. Rattling and whirring sound from engine bay/under car
  97. Clunking when shifting into drive / reverse from park Fixed by TSB: ITB13-008B
  98. Climate control, entire cluster, CD player AND Back-up cam not working
  99. How do I get this little thing of tint out?
  100. Headlights Alpha Rex
