Issue With Gauge Cluster Gauges
Old Mar 7, 2025 | 11:23 PM
Butane's Avatar
Butane
Hi, After removing the interior and putting it back together I noticed a new issue, My Temp, RPM, Speed, and Fuel Gauges do not work anymore. I have replaced the IPDM, checked fuses, and Am about to swap the BCM once I get a key programmed to it but besides that Im not sure what else I should check apart from fuses and ground?
Old Mar 9, 2025 | 03:01 PM
Butane's Avatar
Butane
Okay so on a old post in this forum there is a discussion about this. It is stated that the harness for the radio and A/C have a identical connector that could be swapped and causes issues. There are actually two connectors that can be swapped not one. Both connectors have a yellow tape wrapped around them and both of those belong to the A/C amp. This will cause and/or Gauge cluster issues, A/C issues, Light issues.
charlie_lemmo
Jan 26, 2024 09:39 AM
22BR
Apr 12, 2022 01:55 PM
loganbelmont15
Aug 24, 2021 10:41 AM
iVector
Nov 22, 2020 11:20 PM
iVector
General Tech Questions
Nov 11, 2020 11:07 AM
