PDA
View Full Version : G37 Sedan
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. Completely locked out with a dead battery
  2. Won't shift past 3rd
  3. Amsoil transmission fluid
  4. Exhaust Leak - Y Pipe?
  5. Weird sound when accelerating
  6. Power mirrors not working after bucket seat install
  7. First rattle
  8. Where to buy Infiniti/Nissan parts online in Canada
  9. Noise After Hitting Bump
  10. Rattling noisy, Is there something wrong with the engine?
  11. Weird Noise in Sport Mode at Highway Speeds
  12. 2012 G37X Rear Seat belt Replacement
  13. Dual exhaust pipe size 2.5" or 3.0"
  14. Wheel fitment/mounting issue help?
  15. Aftermarket Strut/Shock Options for AWD
  16. 2013 Sedan U0100-00
  17. Where can I buy Illuminated kick plate T-harness?
  18. Powertrain P0500 & P0720 faults after car's body wash
  19. Headers for G37x?
  20. What's the OEM part number?
  21. Question about misaligned gas fuel door
  22. Upgrade my 2012 to Apple CarPlay
  23. 6MT Bucking During Engagement
  24. Tanabe Medallion AxleBack g37
  25. 2010 g37 sedan s
  26. Driver’s door trim color match
  27. KW Coilovers
  28. Why does my car shut off completely when going into Drive or Reverse
  29. Ordered a 2nd set of FI Resonated Cats
  30. Looking for a mechanic in Randolph NJ
  31. JDM side mirrors. What years?
  32. Wrapped in Lamborghini Color: Grigio Telesto
  33. Anyone have experience with exhaust flange repair kits?
  34. 2008 G37 6MT VLSD to 2008 G35 5AT Open Diff
  35. CEL light after filling up
  36. Center Console Problems
  37. Brainfart charging battery.. removed positive first. Negative still connected
  38. Keyless Entry
  39. Long tube headers installation
  40. Replacing Crossmembers
  41. Water got under the carpet from the storm (soaked still for 7 days). What to do?
  42. Leaking gasoline
  43. G37 sedan test pipes questions
  44. Upgrading to akebono BBK
  45. Anyone have a g37x Sedan Luxury? What is luxury difference?
  46. 09 G37X Sedan Inner Timing Cover Replacement
  47. Can someone check my data logs and see how my cars running?
  48. Windshield Sun Shade
  49. 2013 G37 Valve Body Swap
  50. What is this behind my dash?
  51. HELP g37 sedan halo interference noise
  52. G37x fuel injection
  53. Anyone here that would actually choose a used Audi A6 over their g37x Sedan?
  54. Oil in spark plugs
  55. G37 Ashtray assembly removal
  56. Need help identifying this sound
  57. 2008 G35 Journey Open Diff to VLSD Swap
  58. G37x sedan with all rear 370z sport rays
  59. need help identifying this sensor
  60. g37 Journey Diff Swap
  61. 2010 g37x front end clunking and squeaking.
  62. How to tell if ODO was rolled back on a pre-owned car?
  63. Suspicious G37 Sedan Mod (part 2)
  64. Can these 6.5 speakers fit in my 2012 g37?
  65. Considering a 2012 G37x Sedan - anything to be aware about?
  66. Suspicious G37 Sedan Mod
  67. Cat delete advice on g37 sedan
  68. Throttle lag
  69. Determine trim/options
  70. 2009 G37 Sport VVEL Relay
  71. Bizarre fuel gauge / instrument cluster issue
  72. Does the 2010 g37 come in a 6 speed automatic?
  73. Restoring and Upgrading Suspension Project
  74. How to open up tail lights
  75. G37 sedan quad tips
  76. 17" stock rim tire sizes
  77. Replacement Emblems G37x
  78. Replacing Axle shafts; any advice?
  79. BCM year matter?
  80. I'm throwing a bunch of codes
  81. Overheating with AC (Idle Only)
  82. Rumbling sound from front of car
  83. Xenon Headlight Out - Questions
  84. Issues with VQcarboncustom
  85. Rear diffuser
  86. Z1 Rear Subframe Collars
  87. 2012 G37X sedan Exhaust Cutout
  88. 2012 G37X sedan Exhaust Cutout
  89. Do I need an exhaust/test pipes for power?
  90. License plate light bracket badly rusted(rear)
  91. Engine Light
  92. Water Pump advice for a 2009 G37 Sedan 6MT
  93. Sunroof delete
  94. 7AT leaking sticky fluid
  95. Z1 Upper and Lower Manifold
  96. PPE headers G37X
  97. G37s is faster off the line
  98. 2013 G37S clutch replacement
  99. Akkon Headlight Housing LED Upgrades
  100. Drivers side hump in floorboard
