- Anyone got kinetix HFCs with an otherwise stock exhaust?
- Choice of performance parts
- AGM Battery / 2009 G37 Sport
- Additives - Fuel or engine
- Coolant Drain and Fill, Thermostat and Upper/Lower Radiator Hose Replacement
- Z1 Sedan Cat-back Touring Exhaust
- Fuel Damper & Related Issues
- Rear-ended (accident) insurance question
- Who has been a member here for the longest time?
- Coolant hose replacement help needed
- Battery terminal lug nut combo
- physical key doesn't work - can't open hood
- Engine Failure
- Key fob won't START or ON or ACC
- Lower Radiator Hose Leak
- Electrical Issues
- Coolant issues
- 2010 g37 weird noise
- PIcked up a G37x recently. Lots of traction control issues
- Brake/Traction lights upon acceleration
- Recommendations for anti-theft rear license plate screws?
- G37x AWD Track Help
- Infiniti vs Nissan parts and dealers (working on cars)
- Aftermarket Tail lights
- Stud Allen Key Size
- Trunk latch, rubber bumper replacement
- Strange drip
- 370z Y-Back on a G37 Sedan!
- Code p1092 FSM procedure
- Code 1734 from my 2009 G37 Sedan
- Dash lights and meters off
- Opinions on this exhaust
- Fuel Damper replacement
- Won't start one click only
- Headlights
- G35x drop of rpm around 1k and 2k
- 7AT transmission compatibility questions
- Where I can get a painted bumper?
- Question about bracket under exhaust
- AC working intermittently
- Resonators for Y-Pipe
- Bad cats
- Catalytic converter demon bolt wont come off
- 2008 G35 sedan: Dying battery issue NOT ITB
- No power this morning - Anyone have this?
- P1571 code help
- Fuel injector replacement
- Help With this Dash pop up
- Alignment/handling issues
- Reverse Signal Question
- Bluetooth in a 2010 non nav g37
- Will 245/55 R18 winter tires work on my G37
- Rough idle and acceleration but no check engine light
- 500 RPM when in Drive Cured via Nissan Data Scan 3
- Wheel Weights
- G37x Sedan Electrical issues
- G37 Stainless Steel Brake Lines
- Repair Cost Question
- Throttle body
- 09 G37x head unit
- Coupe subframe fit on sedan?
- Help Identify stolen modules
- Need Help with my custom tail lights
- Clunky first to second gear shift at wide open throttle
- Key Fob and Lag issue
- Help with Coilovers
- Exhaust Questions
- 07-08 g35 sedan g37 sedan bash bar
- Air bag issues
- Engine Noise/Tick Not any common issue
- Found this under my car
- G37 6mt sedan clutch and timing issue
- Muffler Delete on my G
- Lowered Front Camber Issue, Help!
- Former 2018 Accord 2.0T owner
- Transmission fluid maintenance interval
- Bigger tire size for the G37
- Looking for front, passenger side fender replacement
- Help With exhaust
- Issues with headlight bulbs
- Looking for splash guard bolts with extra wide washers
- Bumper Difference
- Weird Car Humming Noise when driving 60-80mph?
- Don’t know what’s wrong with car
- G37sx Sedan Front Bumper Cover
- 2009 G37xs grille emblem replacement
- G37xS AWD with Coupe Wheels Help
- Q50 Center Console Head Unit Conversion 2013 g37x sedan
- Header and test pipe install
- Help With Gremlins
- Upper oil pan
- Newbie Q40 Owner with Cat Question
- Retrofitted Taillights Pics
- cruise control buttons
- Help G37X 2011
- Dorman / PowerTrain Industries Rear Drive Shaft = Junk
- 2013 G37XS sedan rear sway bar upgrade
- Infiniti Maintenance Advantage Front Wheel Bearings = Garbage
- Key fob help
- My screen blacks out
