PDA
View Full Version : G37 Sedan
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. 2010 G37x unresponsive
  2. Best Mods for NA power for G37x sedan
  3. 2013 G37 No Bluetooth streaming or Aux
  4. low pro rain gaurds
  5. Paddle shifter
  6. Rough idle and driving problems
  7. Bad Handling/Corners
  8. Wider tires on stock G37S rims
  9. Brake Upgrade
  10. Max mph?
  11. Buying new Rims
  12. How good is the G's safety in a rear end collision?
  13. New Years Horror story. Airbgas deployed after changing car radio
  14. Spacer question
  15. RWD model sway bar on AWD?
  16. 2009 G37x Sedan Exhaust
  17. Tire Size
  18. My opinion on my G
  19. Missing cover under car?
  20. Vq37: DE? HR? or VHR? WHICH ONE DO I HAVE?
  21. Different speedometer speeds displayed, can someone please explain?
  22. Fault Codes
  23. Reverse lights and camera not working
  24. What diffuser?
  25. 2013 g37x p2098 post cat fuel trim system bank two
  26. Anyone here put mustang Racing wheels on their car?
  27. Getting TERRIBLE gas mileage
  28. Unintended acceleration
  29. What's your mileage?
  30. Stock cats to what?
  31. 2010 g37x bumper conversion to sport (foglight trim)
  32. Limp Mode
  33. Exhaust Leak - Advice Needed
  34. Not starting
  35. G35 Bumper Cover Compatibility
  36. License Light Lamp Bracket
  37. How many miles do you have?
  38. Show me pics of your paddle shifter extenders
  39. suspension noise in passenger side front end annoying as hell
  40. Gap between fender and front bumper
  41. Bolts Rusted out for Oil Under Cover
  42. 09 Sedan AWD - Alignment Specs - Was this done right?
  43. 2015 Q40 engine mods for power?
  44. Rear ended hit and run. Taking your guestimates now!
  45. High flow cats pass emissions in MA?
  46. infiniti g37 sedan 189,000 miles
  47. Sub box for 2013 G37x sedan
  48. Clutch Issues, need some help pls
  49. Spray Painting Tips
  50. Obligatory Coilover Question For a n00b
  51. Good tire size?
  52. Traction control lights?
  53. How serious can a transmission leak be? 6MT 09'
  54. Loss of power in low RPM (under 3kRPM)
  55. Sedan vs Coupe Engine Bay for CAI
  56. Maintnance for new to me g37x sedan
  57. Lug Nuts
  58. Newb question about a motor swap
  59. R2C Filter Removal for Cleaning
  60. Rabbit hole of mystery noises 2010 g37x
  61. Spare removal results in low rigidity of trunk liner
  62. G37x power steering
  63. needing better\brighter headlights
  64. Upgrade Front and Rear calipers
  65. G37 Fast intentions resonated high flow cats
  66. AWD exhaust fit a RWD
  67. Did I buy wheels that don’t fit my car?
  68. Quote for Infiniti G37
  69. Strange sound in passenger side
  70. Cold Start brake vibrations
  71. Rear Diff Oil/Gear oil Help!
  72. Who in here drag races their G? If so what ET and what mods do you have?
  73. Strange Starter Problems - Please Help
  74. 2010 Infiniti G37x akkon headlight
  75. Tilt and Telescope (Manual to Powered)
  76. Help Fitment Issues
  77. Custom mid pipe / exhaust help - g37 sedan
  78. Catalytic to Pipe Bolt/Nut Rusted Off
  79. 2011 G37S Limited Edition
  80. Anyone using oil additives?
  81. Winter Car/Daily Driver
  82. Is a Power Coolant Flush OK to do?
  83. wheels get hot after driving a while
  84. Transmission Fluid Help!
  85. Valvoline max life ATF for 2013 g37xs sedan?
  86. Another coolant leak: Annoying heater hose on drivers side
  87. 2013 xs sedan have front differential?
  88. Transmission engagement/ disengagement click
  89. Gauge Cluster moisture
  90. FOR SALE - 2012 G37xS - 121k miles - $10,600 OBO- SoCal
  91. Enkei Duck feet rims or Enkei RPF1 for Rims upgrade?
  92. Windshield wiper replacements: 2020 edition
  93. G37 shift lock permanently pressed. Okey light on
  94. Sport lip installed and couldn’t be happier
  95. Help with Steering column cover part number
  96. Weird thing happened
  97. Loud, hollow, rattle sound
  98. Q50 Paddles in a Non-Sport G37?
  99. Bags of Sand in Winter?
  100. G35-g37
