275 tyre in front?
Old Feb 28, 2021 | 04:03 PM
Philipp88's Avatar
Philipp88
275 tyre in front?
Hi all, guys!
Has anyone use 275 tyre in front ? (i want to try 275/30/20 all around)
Will it be too hard for steering rack?
Thanks!
Old Feb 28, 2021 | 06:19 PM
iCrap's Avatar
iCrap
Think it should be fine. I am running 265 fronts with no issue.
Old Mar 1, 2021 | 09:30 PM
gord27's Avatar
gord27
Planning to run square 18x9.5 275/40 this spring. The big offset thread has one or two people with that setup. I never thought about steering rack issues. Hope I'm OK!
Old Mar 3, 2021 | 04:42 PM
projectpanda13's Avatar
projectpanda13
This sedan run 275/40 square. He runs that tire on some staggered wheels, 18x9.5 +33 and 18x10.5 +4_ (i forgot the exact offset of the rear)
Old Mar 5, 2021 | 03:12 AM
Philipp88's Avatar
Philipp88
Where can i see more photos of this car ?
Thanks for your answers, guys )
Old Mar 5, 2021 | 08:08 AM
projectpanda13
His name is Brad Yates on facebook. He's very active in the G and VHR pages
Old Mar 9, 2021 | 10:38 AM
BoomerSpeed01's Avatar
BoomerSpeed01
Not to question his setup, but what's the point of running the same tire on staggered wheels? Wouldn't trying to stretch the tire on the rear affect the contact patch?
Old Mar 9, 2021 | 11:30 AM
projectpanda13
the contact patch and dimension of the 275mm tire does change between the 9.5 and 10.5 . He probably enjoys the neutral steering that comes with the square tire setup.
I always forget how the wider wheel changes the contact shape. i've only done testing on same tire, different wheel width, and different air pressure and load.
Old Mar 9, 2021 | 11:42 AM
BoomerSpeed01
Why not have a square wheel setup then? Is there something to gain by having a staggered wheel setup with all the same tires vs a square setup all around?
Just trying to get a better understanding of the reasoning behind this. I plan to autocross my sedan in the future.
Old Mar 12, 2021 | 09:04 AM
projectpanda13
I can't fully speak for his reasoning. I know he has mentioned that he likes those wheels and are pretty rare and got it as a staggered set.
Old Mar 18, 2021 | 05:37 AM
Philipp88's Avatar
Philipp88
Guys, sorry for my english, i didnt understand some of your terms )))
Finally, 275 tyre in front will give me any problems with steering on the road or maybe it will give more workload on front suspension ?
I hope, I was able to express myself correctly
Old Mar 18, 2021 | 02:35 PM
gord27's Avatar
gord27
I don't imagine this would be an issue but would love to hear what a more technical member of the forums thinks since I'm also going to be running a 275 setup in front this year.
Old Apr 5, 2021 | 04:07 AM
Philipp88's Avatar
Philipp88
Just install 275/30/20 all around!
For your judgmnet
Some people says. that 275 tyre will load powe steering system, and i will buy new pupm very soon.
What do you think about power steering ?
Thanks!
Old Apr 5, 2021 | 08:16 AM
ryanwhite74115's Avatar
ryanwhite74115
For your judgmnet
Thanks!
Honestly in all my years owning this car I've never contemplated the additional load from a significantly larger contact patch on the power steering pump. I could see it making a difference. Mine did effectively die at 90k.
Old Apr 6, 2021 | 04:05 AM
Philipp88's Avatar
Philipp88
I dont understand, why your steering pump died at 90k ?
I have already 139 00 km
