Broken doors
Old Feb 24, 2021 | 10:47 AM
Jacen's Avatar
Jacen
Broken doors
Hey guys I was wondering if anyone here had a solution to both passenger and driver side doors not opening, I have 0 feed back in the handles on both sides. I’m guessing the wire snapped off. But since I cannot open the door from either side I cannot get the door open to take off the panel to look.
Old Feb 24, 2021 | 11:09 AM
13_SkylineSedan's Avatar
13_SkylineSedan
Pardon the obvious but it sounds like your car is simply locked. What year, what model, mechanical key, fob, or I-key?
Old Feb 24, 2021 | 11:14 AM
Jacen's Avatar
Jacen
I know it is not locked because I hear the locking mechanism working when I press the key. And I have a 2008 g35. (Figured I’d post it here because everything is basically the same between the 35 and 37). And yes I have a key fob
Old Feb 24, 2021 | 11:28 AM
JSolo's Avatar
JSolo
Just say no!!!!!
Actuators shot? Both at the same time though... not usually likely.
Old Feb 24, 2021 | 11:29 AM
Jacen's Avatar
Jacen
I guess my driver side door decided to work. Both doors have only broken in winter after the doors had frozen shut and had to be forced open.
Old Feb 24, 2021 | 01:08 PM
Hugh Jorgens's Avatar
Hugh Jorgens
Well...that helps narrow it down.
Maybe have someone take the inner panel off and inspect for broken parts or find where the water is getting in to allow freezing.
Old Feb 24, 2021 | 02:00 PM
Jacen's Avatar
Jacen
That’s the problem I’m facing I can’t get the door open to fix it
Old Mar 1, 2021 | 03:39 PM
Noogie Lamont's Avatar
Noogie Lamont
Try using some Silicon spray in the door locking mech(The latch part on the door) The issue is maybe your Mechs are freezing up due to the cold temps. I have had a few cars that have done this over the years especially worse when the temps went below zero.
G37xMN
Feb 25, 2020 10:25 AM
BillyTheMan
General Tech Questions
Jan 29, 2020 06:52 PM
TommyBluez
Jan 7, 2015 07:11 PM
redcoupe
Feb 15, 2014 02:15 AM
joeposter
May 14, 2008 02:03 PM
