Coilovers settling or something else
Hey everyone! I have installed the Truhart street plus coils on my 2011 G37x. Been about a week to week and half, went on a weekend trip to cali and came back to find the right rear lower than all the other corners. I was thinking it’s the coils settling but wouldn’t the rest settle as well? (Dropped about a finger more)
also, maybe off topic but the tpms light is on as well, but all the tires seem fine. I am taking it to a tire shop to check out the tpms and to see if they can pinpoint the lowering of the right rear.
thank you in advance!
Well you shouldn’t really have much settling at all, but I’d be checking the height adjustment collars for sure.
Are the wheels learned to the car? If they are and the tires are all full then you likely have a bad sensor.
Update to the tpms, there’s a nail in my sidewall that is not patchable so I will need a new tire.
I’ve been emailing Truhart regarding the coil over issue, they’re not sure if it either. But I know I did double check the height of all 4 corners to make sure they’re even, but now the right rear sits lower after a few days. Will be checking the height and collars this week
Anytime you do an adjustment, make sure to paint a line from the collar to the body so you can quickly see if it has come loose. A buddy of mine had someone install coilovers for him on his BMW, the next day he left to go to H20i ocean city, when he got back I had to look at it because he heard a noise his whole way back, well one of his collars came loose, and the body had actually completely separated. It was completely wrecked by the time he got home.
Dr.Pat
Jan 30, 2012 01:32 PM
